Old 05-20-2019, 07:47 AM   #1
Water Leak Under Kitchen Sink
So it is me again! Appears that the water is coming out from the joint just below the sink. I am not sure but feels loose and wondering if I need to loosen it and push the pipe up? Just don’t want to make it worse! Appreciate the help! Click image for larger version
dannyr55 is offline   Reply With Quote
Old 05-20-2019, 07:57 AM   #2
Flybob's Avatar
Might just need to have the large plastic nut tightened. Caution: Hand tighten only do not use tools.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-20-2019, 07:59 AM   #3
There are plastic washers there. Put bucket under P trap to catch water. Remove the P trap and inspect them and reinstall.
Rdeejr is offline   Reply With Quote
Old 05-20-2019, 08:02 AM   #4
NMWildcat's Avatar
If tightening the collar doesn't fix the leak, you might have to disassemble the p-trap and examine/adjust/replace the plastic slip joint washer.
Usually tightening the collar does the trick (hand tighten only). I tighten/check all mine at least once a year.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is offline   Reply With Quote
Old 05-20-2019, 08:04 AM   #5
if it is leaking from exactly where you are pointing, that fitting can be tightened and it seals the drain pipe and the trapnec. Threaded and self tightens. There is also a washer/seal that seals the connection.
Id tignten first. If this does not stop the leak then loosen the connection completely and check the seal ring. It could be twisted/crimped or missing.
Of course it also could be the sink drain connection and leaking down to that fitting.
Pretty simple stuff normally unless there is a crack
gbaldwin is offline   Reply With Quote
Old 05-20-2019, 08:08 AM   #6
NMWildcat's Avatar
It appears great minds think alike!
Old 05-20-2019, 08:36 AM   #7
Thanks to all the great advice! I disassembled the P trap and checked the seals and both appeared okay. I reinstalled and made sure the pipe was far enough up to the sink. Hand tightened the nuts and just like y’all said, no more leak! Thanks again for the quick responses!
Old 05-20-2019, 08:58 AM   #8
NMWildcat's Avatar
Congratulations! Glad the simple fix worked for you,and thank you for letting us know the results. Happy RVing!
Old 05-20-2019, 09:02 AM   #9
Gumpster808's Avatar
Glad it worked. Now you are a plumber for your RV. These things are good for upping various repair skills [emoji3]
2014 3051S - First RV for us
Gumpster808 is offline   Reply With Quote
forester, leak, sink, water, water leak
