Old 04-28-2019, 02:18 PM   #1
Water pump
I have a 2016 Sunseeker 2430S with a non-functioning water pump. All the fuses in the converter compartment appear to be good. I would like to see if a fuse is located near the pump itself which may be bad. I am unable to locate the pump (can’t hear it )
sandan2430 is offline   Reply With Quote
Old 04-28-2019, 02:38 PM   #2
nomad297's Avatar
I think it is under your bed.
Bruce
Old 05-01-2019, 10:16 AM   #3
Bruce
Thanks Bruce
I will check it out as soon as we return home and let u know what I found out.
Dan
Old 05-01-2019, 10:47 PM   #4
Usually Confused Member
emm-dee's Avatar
Check the wire connections at the pump. It’s not uncommon for the factory to not firmly set the wires and they vibrate loose.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
pump, saunseeker, sunseeker, water, water pump
