Old 04-29-2019, 08:00 PM   #1
ScubaSteve71's Avatar
Water Pump
So I tried using my water pump. Put water in Fresh Water tank. I didnít fill it all the way up though. When I tried to turn on water nothing but air coming out. I closed all faucets thinking it need to build up pressure but it only spit out a little water then air. What should I do to trouble shoot? Oh itís a 2013 Sunseeker Class C.
ScubaSteve71 is offline   Reply With Quote
Old 04-29-2019, 08:25 PM   #2
let it run longer with faucet open remember it may be filling the hot water heater to if you just dewinterize. give it a min or 2 and make sure you, put in enough water some tanks will take 5 gallons before it reaches the pump suction line
MR.M is offline   Reply With Quote
Old 04-29-2019, 08:27 PM   #3
Thx I will.
Old 04-29-2019, 08:55 PM   #4
A32Deuce's Avatar
Took mine a good 5 minutes of running to get all the air out after dewinterizing. Water filter to fill, all the water lines and of course the water heater, maybe 8 or 9 gallons of water!
A32Deuce is offline   Reply With Quote
Old 04-29-2019, 08:59 PM   #5
Thx maybe I just need to wait longer.
pump, saunseeker, sunseeker, water, water pump
