Old 02-05-2019, 04:36 PM   #1
Water Pump location on 2019 Sunseeker?
Does anyone know where the water pump is located on a 2019 Sunseeker MBS?
There's a convenient by-pass switch near the shower.
Also, I don't see any label for a Low Point Drain but there are 3 (count them) drains coming down under the camper (2 white and one red hose) which I also don't know what they are... I suspect one of them is a freshwater drain.
The manual (on-line... no old fashion paper manual) is generic and not specific... IMHO.
2019 Sunseeker MBS
roncurl is offline   Reply With Quote
Old 02-05-2019, 05:13 PM   #2
I'm sorry i can't help you with the location but turn on the pump and walk around (inside and out) and listen for the noise it makes running.
Most manuals and online documentation is generic. That is what the PDI/Customer Orientation is to to do, bridge that gap. Did your dealer not show you these important R/V 101 items?
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 02-05-2019, 05:41 PM   #3
fonzie's Avatar
This thread might help you...
http://www.forestriverforums.com/for...bs-148705.html
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 02-06-2019, 07:50 PM   #4
I appreciated the suggestions. Here's the update. In short I've found the water pump and I'll try to post a pic for it.
The water pump in the 2019 Sunseeker MBS is under the shower. There is a by pass valve outside the shower (near the floor). AND if you remover the panel next to the valve (4 screws) you can see the pump AND a tube that can be used to add anti-freeze (Winterize).
Name:	Water pump & by-pass hose.jpg
2019 Sunseeker MBS
cat, location, pump, saunseeker, sunseeker, water, water pump
