06-02-2017, 02:15 PM
Water regulator
We have a 28-foot Sunseeker. When we hook up to city water we use a regulator that we attach to the spigot then we attach the hose that runs to our RV.
We usually don't get very good water pressure when we do that. We get better pressure when we use the fresh water tank and water pump.
Someone at the campground said it may be because our unit has a built-in regulator for city water connection and we are basically doubling up unnecessarily.
I looked through our manuals and couldn't find anything about an internal regulator.
Any thoughts or suggestions would be helpful.
06-02-2017, 02:31 PM
There isn't a built in water pressure regulator, unless someone added one after FR built your Sunseeker anyway. You are doing it the right way so it sounds like the campground may have low water pressure...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
06-02-2017, 03:29 PM
Either the campground has low pressure or your regulator is the problem. We have the best luck with a cheap 50psi high flow regulator.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-02-2017, 03:42 PM
as others have said connecting the way you do protects both your rig and your hose. I have had problems with the inexpensive non-adjustable reducing regulators and water flow. I went to the adjustable type regulator with a pressure gauge and have had much better luck with pressure and flow.
Retired Navy
2016 Flagstaff 26 FKWS
06-02-2017, 03:56 PM
What I use, when I use one. Keep it in the drawer just in case.
Additionally, hope you are wipiing / spraying the spigot end off with a bleach solution prior to hooking up your water line... You never know where the last users hands were when they unhooked theirs.....
Could have been on their black water connection prior to....
06-02-2017, 05:23 PM
Not sure where you are using your regulator but try using it as close to your rig as possible. Using the regulator at the city spigot before the hose can cause pressure issues, and the longer the hose the higher the possibility. I screw in my 90 elbow to the trailers city inlet then the regulator directly to the elbow.
Edit: reread your original post, saw you are connecting the regulator at the spigot.
06-02-2017, 05:46 PM
X2
Keep the regulator at the spigot.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-02-2017, 05:48 PM
Probably not a bad idea, but I never have used a bleach solution for that.
1966 Mustang GT
1986 Mustang SVO
06-02-2017, 06:40 PM
We do it before and after using the spigot. And, yes, keep the regulator on the spigot end.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
06-02-2017, 08:11 PM
Not a bad idea but in the 35 years of camping never have but I drink out of an unfiltered creek too
1966 Mustang GT
1986 Mustang SVO
06-09-2017, 06:19 PM
I saw a guy rinse his sewer hose with the potable water spigot...
06-09-2017, 08:49 PM
I keep a small squeeze bottle of bleach/water solution in the camper when I know we are considerring staying anywhere there is city water available and I fill my unit at Cabelas before a trip..I spray that spigot as well.
People do the most inconsiderate things, I prefer not to get sick from some clown's stupidity.
I have a gauge on our pressure regulator, but at one point I tried a Y adaptor and it greatly reduced throughput. Pressure was fine but you would turn on the shower and it was fine but would drop to half in seconds. I suggest you check your hoses and or connectors. My Y adaptor used a small ball valve that was restricting the flow so I removed it and solved my problem.
Good luck.
06-10-2017, 03:35 PM
Chief tinkerer
Jbmcbride, if you haven't already looked, some of these have a fine mesh screen that can get clogged.
Gary
2017 SunSeeker 3010DS
