Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-04-2021, 07:57 PM   #1
Water squirting out of fill cap
I have a sunseeker 3010DS when its hooked up to city water and after the tank fills, water is squirting out of the outside manual tank fill cap. I replaced the pump motor, replaced the o-ring in the water filter and replaced the smaller inline filter and housing.
Also not hooked up to city water and the pump is turned on all i hear is bubbling inside the water tank. I assume there is air leaking in but cant find the leak.
kitejunky1 is offline   Reply With Quote
Old 12-04-2021, 08:44 PM   #2
Certified Curmudgeon
Duckogram's Avatar
Bubbles
Is it possible that the pump is mounted backwards? That would prevent the internal check valve from working and allow city water to fill your FW tank quickly. When disconnected from city and the pump is activated it would pump air into the FW tank.
The inlet side of the pump needs to be on the left.
Here is one that works. Note the pressure switch wires come out the back.
Ducky Sez; My posts are intended to help with technical and maintenance issues for F/SS only*. I do not measure skin thickness and nice is just another four letter word.
Old 12-04-2021, 09:06 PM   #3
Thanks i am sure you are right, cause when i got the pump it was facing the wrong way so i unscrewed the top and turned it 180.. Thanks for the reply and i will post results tomorrow after i turn it around.
water
