Old 03-08-2018, 07:08 PM   #1
Sewgratefulquilts's Avatar
Water Tank Fills When On City Water
I tried searching for info on the problem but couldn’t find anything.
We hook up the water hose at a campground, turn the lever to city water and the fresh water tank fills. At first it would fill slowly over a couple of days, but now the water goes directly into the fresh water tank. What’s going on?
Sewgratefulquilts (Linda)
2017 Class C Forester 2371 Transit Series
Hubby, Craig, and Miniature Poodle, Beau
Sewgratefulquilts is offline   Reply With Quote
Old 03-08-2018, 07:14 PM   #2
ejohnson1144's Avatar
Bad check valve
Sent from my LG-H910 using Forest River Forums mobile app
ejohnson1144 is offline   Reply With Quote
Old 03-08-2018, 07:16 PM   #3
I saw this last week. check valve in water pump sticks. there is a way you can possibly reset it without tearing into it. I'm sure some one with the specifics steps will chime in.
Kimber45 is online now   Reply With Quote
Old 03-08-2018, 07:19 PM   #4
Go to the search box in the upper right corner. search "Water pump check valve" you will find hours or reading.
Old 03-08-2018, 08:31 PM   #5
Certified Curmudgeon
Duckogram's Avatar
You may be able to clear the problem. Disconnect City, release all pressure, turn pump on with cold water open (anywhere). Shut water off. Wait until pump stops, turn pump off. Release pressure. Reconnect city. Keep fingers crossed.
If that does not clear the check valve, you might have to clean it. 4 screws to remove it. Its just a rubber diaphram.
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
Old 03-08-2018, 08:34 PM   #6
I am at the end of a two month trip and the same thing happened to us three weeks ago. I did the research and the best solution that worked is to turnoff the city water, with the pump off open a faucet to relieve pressure, then close the faucet and and open the city water valve. The city water pressure can seat the check valve better with no pressure behind it. This has worked for the last three weeks, I will take the pump apart and inspect/replace the check valve after we get home.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is online now   Reply With Quote
Old 03-08-2018, 08:43 PM   #7
You've received correct answers about the water pump check valve and how to reset it.
Sorry you had issues searching this issue as it is one of the most discussed topics on the forum.
One more thing... are you using a quality water pressure regulator on the city water supply? High city pressure can often overcome the pump's internal check valve.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 03-08-2018, 08:47 PM   #8
Flybob's Avatar
Answers above should solve your problem. Do not run water pump when on city water.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-08-2018, 09:03 PM   #9
Mr. Dan's Avatar
5picker and Flybob, would this be a good time to consider this fresh tank/city water valve as a suspect in this crime? I have independent "openings" - not a single "opening" with a lever. I think I've read these switch-over valves can also stick/fail. Just asking.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 40; Booked for 2022 = 70
Old 03-08-2018, 09:29 PM   #10
I had that happen when I mistakenly turned on the water pump while attached to city water. It filled my fresh tank. I was in a FHU site so I turned off the city water and used the water pump to pump the water to the galley tank which emptied to the sewer connection. When the tank emptied I turned off the pump and turned the city water back on. No more issues but now I am really careful about switches.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
Windjammin is offline   Reply With Quote
Old 03-08-2018, 10:14 PM   #11
Well, it's certainly a possibility to consider since the valve mentioned does provide a path for city water to enter (fill) the tank as that's its real job.
I've just never seen one fail but that doesn't mean they don't.
Old 03-08-2018, 10:45 PM   #12
Thanks for the answers. Will give the suggestions a try.
Only once did I accidentally leave the pump on when using city water for a quick moment. As soon as I heard it I shut it off.
How do you know if you have a “quality water pressure regulator?” Bought the brass one the dealer suggested for @$8.
Ran the search again for water pump check valve and found nothing. I’m in the Forester section. Should I be somewhere else?
Really appreciate the help. I used to do nothing but cook and clean and enjoy the ride. Now I’m driver, repairwoman, trip planner, financial planner, caregiver, etc., etc. Trying to give him some happiness while I can and rving is the only thing that interests him. This forum has helped so much. Teaches me what to look for and how to do some things for myself. Never thought I’d be using a screwdriver or figuring out how to use an air compressor. Maybe I should buy an Rv repair book!
Thanks everyone.
Old 03-08-2018, 10:52 PM   #13
Mr. Dan's Avatar
This problem is not unique to Forester. Don't use the 'Search this Forum' function. If you are on the full site, use the Search 3 places from the right end of the green bar near the top. It's between "New Posts" and "Quick Links".
Old 03-09-2018, 11:34 PM   #14
Had this problem for over a year
I day this same problem. I tried all the suggested fixes. I notice that the pump kept running and never building up pressure completely. I thought i had a leak in plumbing. there was no leak when on city water. So i kept believing that something was keeping the check valve from seating. The pump is a year old but I check it anyway and found that the screws holding diaphragm in was not real tight. I tighten them and pump started working properly building up pressure and shutting off. I was excited. So i hooked up city water and after several hours tank is not filling up anymore.
brightstar is offline   Reply With Quote
Old 03-09-2018, 11:53 PM   #15
Scoundrel
HangDiver's Avatar
Thanks everyone.
You are a remarkable woman. You don't need to buy an RV repair book. You already have one here.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
city water, tank, water, water tank
