Old 09-13-2018, 04:59 PM   #1
What is this?
It is located under the motorhome right behind the generator.
Kim
bayoubelle is offline   Reply With Quote
Old 09-13-2018, 05:59 PM   #2
Originally Posted by bayoubelle View Post
Attachment 186383
Are you referring to the wire loom, the cable or whatever is behind it?
can you describe what is behind?
Old 09-13-2018, 06:37 PM   #3
I’m talking about the rectangular object with the rows of squares.
Kim
Old 09-13-2018, 07:13 PM   #4
Splitshaft's Avatar
I am not sure, what make, model, and year vehicle are was inquired about here??? It may be part of the evaporative emissions controls for a gasoline engine. It is clearly for the chassis and not the coach.
Splitshaft is offline   Reply With Quote
Old 09-13-2018, 07:22 PM   #5
Sorry. It’s a 2017 3010DS
Kim
Old 09-13-2018, 07:42 PM   #6
Splitshaft's Avatar
OK cool. Then it must be on a Ford cab and chassis. That will help someone who owns a Ford cab and chassis help identify the component. I am not familiar with the Ford cab and chassis to say for sure the device is other than I suspect it is part of the emission control system for a gasoline engine.
Old 09-13-2018, 08:00 PM   #7
I cant remember exactly what it was called. Last year I searched the molded in part number on the box. It came back as part of the evap/emissions system.
This was on a E450 chassis.
Edited to add.
Found the part on fords parts site. It is the fuel vapor canister, definitly part of the evap system.
2021 Newmar Baystar 3401
2019 Jeep Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 09-13-2018, 10:25 PM   #8
Splitshaft's Avatar
Edited to add.
Then that would be what they call a “charcoal canister” in the industry. Fuel vapors from the fuel tank and/or fuel system are collected there and then burned in the engine when running so our environment is not polluted with gasoline vapors.
Old 09-13-2018, 11:36 PM   #9
Thanks for the responses. Now I know what it is.
Kim
