Old 08-21-2007, 12:07 PM   #1
What is this?
I have a few hoses like this, what is this for?
Thanks.
wengerda is offline   Reply With Quote
Old 08-21-2007, 12:38 PM   #2
Looks to me like a capped off cold water line that could be used for adding on. Have you tried to un-cap it and see what happens? Might be fun!
aintgotnun is offline   Reply With Quote
Old 08-21-2007, 04:53 PM   #3
Smile
Looks like one of the low point drain lines. You may want to e-mail Ashley Evans at aevans@forestriverinc.com and ask for the complete set of Sunseeker manuals for your specific model. They cost $25 plus shipping and are worth it. You might also want to call Mike Burns (Sunseeker Rep) at 574-206-7603. One of his functions is to answer our questions. Hope this helps!!
edcaroleg is offline   Reply With Quote
Old 08-21-2007, 10:13 PM   #4
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
That's what all my low point drains looked like on my Keystone Outback.
Haven't crawled under the new one yet....
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 09-24-2007, 10:55 AM   #5
Okay, I purchased copies of the camper's manuals, and there in no where shows this blue/red hoses. Can anyone please tell me how to open them? The cap does not come out at all, I attempted to unscrew the second ring but there is nothing to come out, unles I yank the top cap from the inside the hose, (the top cab is inserted approximately 1/2 to 1 inch long inserted into the hose. Suggestions? I do not want to pull that cap from inside the hose and then I can not put it back later.
Old 09-24-2007, 12:09 PM   #6
I agree with the low point drain. Just use 2 pairs of pliers, one to hold the main body and one to spin the cap off. These caps must be removed and RV antifreeze run out of them for proper winterization. As a suggestion, put some ball valves in place of the caps for easier draining/winterizing. The plastic threaded 1/2" valves "should" thread right on.
Kilowattkid
2003 F-250 5.4 manual gearbox w/ 4.10's
2007 Puma 29RKSS
kilowattkid is offline   Reply With Quote
Old 09-24-2007, 12:19 PM   #7
Okay I will try that, I thought that the caps will come out easily but now I know to use two pliers to assist me to remove the plugs. Thanks.
Old 09-24-2007, 12:24 PM   #8
RAC
It looks like an NDP fitting.
RAC is offline   Reply With Quote
Old 09-24-2007, 12:25 PM   #9
ok, what is a ndp fitting?
Old 09-24-2007, 01:13 PM   #10
RAC
Greg, Does this look like an NDP fitting to you??
Old 09-24-2007, 01:28 PM   #11
RAC
Richard do you know?
Old 09-24-2007, 01:38 PM   #12
That'd be my guess.
Old 09-24-2007, 02:12 PM   #13
What is a NDP fitting???????????
Old 09-24-2007, 02:17 PM   #14
RAC
is that picture from top down or bottom looking up?
Old 09-24-2007, 02:20 PM   #15
RAC
I am going to assume the pic is looking in the engine compartment. That's what it looks like. NDP is No Discernible Purpose. It looks like someone jerry rigged something. If it were a low drain valve it would be near the ground.
Old 09-24-2007, 02:20 PM   #16
The hose is pointing down tot he ground, yes the picture was taken top down
Old 09-24-2007, 02:22 PM   #17
RAC
It REALLY looks like nothing. Like someone jerry rigged something. Where does it go? Did you trace it out?
Old 09-24-2007, 02:23 PM   #18
No engine compartment, the two hoses are in the same side of the black/grey valves, and I have two other ones in the back center near of the bumper. (They are also a red and blue hoses.
I would like to know if I do not find these low point hoses, and I am going to winterize the camper with anti-freeze should I be okay? The antifreeze should go down to the low point also, right?
Old 09-24-2007, 02:24 PM   #19
RAC
the caps are up or down?
Old 09-24-2007, 02:25 PM   #20
the caps are all pointing down
sunseeker le
