Old 09-07-2018, 01:02 PM   #1
Dcbenny's Avatar
What is this light
Does anyone know what this red light may be for. Purchased preowned and dealer did not know what it was for. Located on the left side of dash down by brake release thanks
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 09-07-2018, 01:43 PM   #2
Royston's Avatar
When I set up my MH to pull my car I opted for a ReadyBrute Elite tow bar that has a an inertia brake system. This system has a switch on the tow bar that is activated when the inertia brake operates. In order for the driver to know that the inertia brake is operating an LED is mounted somewhere on the dash, a positive supply is connected to the LED (via small in-line fuse) and the other side of the LED runs to the switch on the tow bar - the other side of the switch is grounded so when the inertia brake operates the switch closes and makes the circuit illuminating the LED.
This may or maybe what this light is on your MH. Take a look near the hitch and see if there is any sort of 2 pin connector like the one in the photo attached.
2011 Berkshire 390RB (Front airbag upgrade & 275/80R tires)
2016 Ford Edge SEL 3.5ltr, Blue Ox baseplate, Ready Brute Elite tow bar, Brake Buddy Advantage Select
Royston is offline   Reply With Quote
Old 09-07-2018, 01:57 PM   #3
Dcbenny's Avatar
Thanks will take a look
Don & Liz B.
2016 GTS 2800QSF
Old 09-07-2018, 04:33 PM   #4
Dcbenny's Avatar
Looked underneath by hitch did not see a plug like that doesnít mean the previous owner didnít remove it
Don & Liz B.
2016 GTS 2800QSF
Old 09-07-2018, 10:38 PM   #5
Ambassador Member
Duckogram's Avatar
Has it ever come on?
Just Ducky
Sunseeker 2800QS
Towing Smart
No PMís.
Separating the Wheat from the Chaff Since 2013
Duckogram is online now   Reply With Quote
Old 09-07-2018, 11:36 PM   #6
Splitshaft's Avatar
I have no clue. Trace the wiring as it could be for anything, including the parking brake. Does not look like an OEM lamp to me. Something of aftermarket possibly. Good luck if an RV dealer has no clue either.
Splitshaft is offline   Reply With Quote
Old 09-08-2018, 06:12 AM   #7
Dcbenny's Avatar
Has never come on, I can see where it goes thru the firewall into engine compartment and that’s as far as I can see. Dealer thought it may be for the Big Foot Jacks. Going to Ft Wilderness in a couple of weeks will dig into it a little bit more when I am there.
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 07:35 AM   #8
Kanadian Kamper
kenandterry's Avatar
Yeah.....looks like a home made indicator to me. I had small lights like this that I installed on several motorcycles over my years.
Iíve driven, rented, owned, bought a number of vehicles over my life and never seen a factory lamp like this.
Come to think of it.....if/when I ever sell our motorhome, I hazard to guess what the next owner might try to figure out with what modifications Iíve made.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 09-08-2018, 07:47 AM   #9
Flux Capacitor "on" indicator light
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-08-2018, 08:08 AM   #10
Kanadian Kamper
Not sure Iíd want to get my motorhome going 88mph to engage the flux capacitor
Ken and Terry
Old 09-08-2018, 08:13 AM   #11
Dcbenny's Avatar
Took another look this morning the white wire that I thought went thru firewall was actually a grounding wire for the light attached to a bolt. On the 3 attached picture it looks like the cut into the blue wire from harness to light donít know what this harness maybe for
ID:	185762   Click image for larger version
ID:	185763   Click image for larger version
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 08:22 AM   #12
Dcbenny's Avatar
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 08:23 AM   #13
In mine, it tells me if the toad brake lights are on when towing.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is online now   Reply With Quote
Old 09-08-2018, 08:49 AM   #14
B and B's Avatar
In the movies when you cut the blue wire bombs usually blow up!
Old 09-08-2018, 09:36 AM   #15
Dcbenny's Avatar
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 02:42 PM   #16
Get the owners manual for your make/model and see if any info in there about it.
patsylou2 is offline   Reply With Quote
Old 09-08-2018, 04:20 PM   #17
Dcbenny's Avatar
Thanks nothing there
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 07:59 PM   #18
Dcbenny's Avatar
After reading some of the post did some research and there is a braking system called stay and play where it has a red light that is mounted on review mirror that lights when the brake is applied and the driver sees it in the rear camera monitor. Several videos show how the cut into the blue wire and mount a red light on dash of tow vehicle so driver doesnít have to look at monitor to see if the brakes activated. By George I think this may be the mistery light on my dash. Thanks for all the comments
Don & Liz B.
2016 GTS 2800QSF
Old 09-08-2018, 11:09 PM   #19
Tbonz's Avatar
Jacks down light??
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 09-09-2018, 12:04 AM   #20
Ambassador Member
Duckogram's Avatar
Lavatory Occupied
Just Ducky
Sunseeker 2800QS
Towing Smart
No PMís.
light
