Originally Posted by gmann55
Cnycamper! Does that mean you were able to roll it up by hand? If that was the case, it was not spring loaded? Is that correct! You would only need the strap if it were spring loaded!
See Wm Tire's Post #6. That is the same manual I referenced when I closed my awning. The manual states the awning is under spring tension and is the reason for inserting the strap while removing the bolts. My awning, however, did not move. The technicians later determined that the motor being completely frozen overcame any spring tension. As stated in my post, I rolled it up by hand (in a pouring rain storm) and reinserted 1 of the 2 bolts (the other was lost in the mud). Hope that answers all your exclamation points.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018, 38 in 2019, 37 in 2020
