03-18-2017, 11:03 PM
What's your top Sunseeker modification?
I went out today to buy a Sunseeker MBS 2400 but walked away with a Sunseeker 2290S (Ford) because of the towing capacity and the price. I will be towing my Jeep Wrangler Unlimited.
I'm thinking through the first modifications I might want to make and I'd love to hear your top modification - the one thing you've changed that was 100% worth it.
03-19-2017, 10:17 AM
Roadmaster steering stabilizer and shocks replaced all around. Inside the dinette removal and replaced w/ recliners. These are the top mods but there are many others.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
03-19-2017, 10:37 AM
DW's 401(k) Plan
Tops so far have been the Roadmaster Reflex steering stabilizer and Blue Ox rear sway bar and trac bar. Plus my 3 MaxxAir covers up top.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
03-19-2017, 11:28 AM
Wait till next year...
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
03-19-2017, 12:03 PM
What shocks did you replace with? Also, do you drive ford?
03-19-2017, 12:06 PM
I did notice on my test drive that I had to fight a bit to stay straight in my lane. I'm sure it'll be even more challenging when I'm towing. Did you install the roadmaster yourself?
03-19-2017, 12:07 PM
Originally Posted by n-e-d
What does it do?
03-19-2017, 12:33 PM
I have the 2500TS and replaced the screen door with a curtain type screen that closes in the center via magnets. I bought mine in Home Depot.
What does it do?
Makes it easier to close screen door and hold on to it as you leave something you'll do often
Mary and Me
03-19-2017, 01:18 PM
Back to RVing again
How'd you do that?
GEEMAN:
I also want to replace the dinette with two recliners. What recliners did you use? And I am looking at the door and wondering how I'd even get them in through such a small opening.
Do you have pics?
Kevin
03-19-2017, 01:49 PM
I would carefully check the tire valve extensions that FR provides. Mine leaked, caused flat tires, and were near impossible to inflate the tire... Pure junk is the best I'd call their plastic straws. Go to DuallyValves and buy a set of one piece metal stems instead of dealing with any type of extenders. To me this is a safety issue and 100000% worth it....
Then you can add a TST 507 Tire Pressure Monitoring System (TPMS) to monitor your tire pressure when you're ready to add it. This is also a 100% worth it mod that improves safety. FYI, unlike passenger cars and light trucks that have had built in TPMS units for years commercial van chassis do not require one...and FR doesn't order it on their chassis.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
03-19-2017, 01:57 PM
Roadmaster Steering Stabilizer
3 MaxAir Covers
bar for screen door
200 watt solar panels on roof
Changed out TV s for Samsung larger ones 3
Removed knife couch for 2 lazyboy recliners
Put high density foam in dinette seating
auto lighting in all inside cupboards and outside lockers
LED lighting through out coach and LED tail lights
Ice maker
Induction cook top
Electric water heater option
Countertop convection oven
Tire Pressure senders and monitor
Portable BBQ
LED awning lights
Engine monitor for trans temp, engine temp, gas mileage etc.
CB Radio
Digital TV antenna
Installed TV in Bedroom and blueray player
Sonos audio system
Water filter and pressure reducer
30 amp pug in electrical protector for surges, and low or high voltage protection
2 - 2000 watt Wen 56200ic inverter generators, with parallel kit, much quieter for boon docking
Separate monoxide and Propane detectors
John B.
2012 Sunseeker 3010 DS
Coquitlam B.C. Canada
03-19-2017, 02:57 PM
We've got the Chevy 4500 and the shocks are Bilstien.
03-19-2017, 03:28 PM
Citrus County, Fl.
#1 is a Progressive Industries hardwired EMS (surge protector and more) thru Randy at Best Converter RV Power Protection EMS
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
03-19-2017, 04:03 PM
Originally Posted by Kevin and Bev
GEEMAN:
Do you have pics?
Kevin
The backs come off the recliners so they will go through the door sideways without problems. I prefer cloth Lazy Boy recliners or leather. No faux leather as they will not stand up.
John B.
Sunseeker 2012 3010 DS
03-19-2017, 04:20 PM
I have a Forester 2451, similar to your SS. The Chevy chassis has not required any mods to keep it on the road. Dinette gone! First set of cheap recliners bought to test feasibility...Gone! New recliners. Luv'em thanks to this forum! Lots of other "mini-mods" including Stowaway cargo pod and we tow a Fiat 500. New custom mattress. Oxygenics shower and upgrade kitchen sink faucet with "pull-out."
Don & Cindy
4 Legged Kids - Emma & Chili
Home Base- Central Florida
2016 Forester 2251SLE
"Pete" the Toad
03-20-2017, 10:00 AM
2 - Fan-tastic Fans with Vent Covers - Seriously you could ALMOST replace the AC with these things. - Easily the best mod on my list
520 Watt Solar - 40A Controller - With moderate sunlight it can easily run all my 12-volt appliances without touching the batteries.
Upgraded to 4 Group 27 Deep Cycle Batteries
12V - 24" Bedroom LED TV
ESI Cam With Magnetic Base to use as Rear View Cam while driving and backing up. I use 2 elastic bands and attach my phone to the rear view mirror.
Motor-home came with several 12V USB Charging stations so not technically a mod but a must have.
2016 Sunseeker 2650
03-20-2017, 02:22 PM
Here is by far the nicest recliner conversion of a Dinnet Area that I have seen. Hedid a great job. A frien just used his idea and done his and its great. Recliners come from CW.
http://www.forestriverforums.com/for...nge-94707.html
03-20-2017, 04:55 PM
Originally Posted by RetiredAF1955-1981
Thanks.
I just cut the main table tube down 1.5" so it is easier to eat.
Probably should have cut it 1" since it is a little tight now but will do.
Still love the setup.
Would not have it any other way.
"If you are going through hell..keep going"
W. Churchill
03-20-2017, 05:08 PM
Chief tinkerer
Originally Posted by Total Loss
Thanks.
I just cut the main table tube down 1.5" so it is easier to eat..
Hey Total, high five.... I did the same. The table on our (SS3010) was a little on the tall side, and I'm a pretty big guy.
Gary
2017 SunSeeker 3010DS
