11-28-2019, 02:14 PM
wheel cover issue/2018 Sunseeker MBS2400
When washing rv, noticed wheel cover was somewhat loose, was able to pull off with no effort!! Noticed that the wheel cover and been rubbing on the extended valve and had almost sheared it off. Luckily was able to detect before some serious damage could occur out on the road. Check wheel covers to make sure they are not rubbing against the tire air valves!!
11-30-2019, 07:26 AM
Zip-tie them or lose them!
2018 Sunseeker 2400R MBS (w/dinette)
2013 Honda CR-V toad
11-30-2019, 08:12 AM
If one does a search on the topic of “Sprinter simulator”, many discussions come up about these covers being noisy or falling off. Apparently it’s a common problem.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
11-30-2019, 10:44 PM
We have lost one front and two rears - tire shop is going to put on 4 new ones in the spring when they rotate the tires, that are secured with machine screws or something = $249
2017 MBS 2401W
12-01-2019, 01:51 PM
Since losing my first one four years ago, I keep mine secured with zip ties and have not lost another one.
2015 Forester MBS 2401 WS
12-01-2019, 01:53 PM
Senior
Use stainless steel zip ties not plastic ones.
12-01-2019, 02:15 PM
Who and where are you having this work done? I've been looking for the same. Thanks!
Bill
2015 Coachmen Leprechaun QB220 (purchased 4/2018)
12-01-2019, 02:52 PM
Where can you purchase replacement rims?
Agreed with above; I’ve experienced noisy, loose rims, and stems getting stuck and twisted inside.
I once tried purchasing expensive stainless extended stems for Sprinters and was told they wouldn’t work on my Solera. Now I’m not so sure; maybe they were just lazy. I recent caught my local Tire Pros claiming in writing that they filled all my suv tires to 35 psi. Fortunately my car has a tire pressure monitor system and when I drove off I knew immediately that they overfilled the one tire they plugged and then failed to fill the others including one extremely low tire that I had repeatedly asked them to do.
12-01-2019, 03:06 PM
You can buy replacements at your dealer or save a lot of money and go to Ebay. Here is an example listing on Ebay. I suspect the only thing that changes between brands is the decal in the center.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
12-01-2019, 07:24 PM
I reported that zip ties have worked for me for four years now. Sailski said to use stainless steel, not plastic.
I'll just add that I started with SS but when I drove to Alaska some of them still broke. This allowed the wheel cover to rotate and rub against my extended metal valve stem, causing a flat tire. Then I switched to plastic zip ties and haven't had a problem since. Of course, they get replaced every time I have the tires rotated.
12-01-2019, 09:12 PM
2012 Solera
Agree on plastic over stainless steel. I use “heavy duty UV resistant plastic zip ties. Tried the stainless steel ones - couldn’t get them as tight as I wanted, and they seemed to loosen further with use.
JLeising
2012 Solera "S"
Calif SF Bay Area
12-01-2019, 11:16 PM
We replaced our first lost cap from Ebay = $100. Our local tire shop in Central Washington State is where we'll get the new caps in the spring.
2017 MBS 2401W
12-02-2019, 09:22 AM
2013 Sunseeker,
Never had a problem with covers staying tight ???
12-11-2019, 11:26 PM
Check. Out Summit Racing. I Threw away the FR wheel covers on my Forester and replaced them with bolt-ones from Summit. They are know for good quality.
12-12-2019, 10:23 PM
Bolt on from Summit Racing? I just looked and saw Phoenix USA brand that have ovals instead of all round holes. How do they bolt on? On mine, there are two screws that ONLY hold the center round piece onto the wheel simulator body. The whole thing comes off together as one piece just like a hubcap. Could you please provide a brand and p/n?
12-13-2019, 09:42 PM
My Forester has oval hand hole in the wheel. I would suggest calling them to see if they have something to fit yours. There is an adapter that screws onto the end of two of the lugs. The wheel cover then screws onto that.
