05-17-2013, 06:50 PM
Where is the fuel filter?
I have a Sunseeker 3120 e450 v10. I looked all under this rig to find the fuel filter but couldn't find it. A camper at a campground also had a class c e450 v10 as well, he said they have a lifetime filter located in the fuel tank. No filter to change. Could this be possible? Doesn't sound right to me.
05-17-2013, 08:02 PM
Plain Old Member
Think he was correct. I've heard the same. I wouldn't say lifetime, just a pain to change should it ever need it. We have the forester version of yours, and I didn't see one either.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
05-18-2013, 05:24 AM
And you looked inside the frame rail under the drivers door??
05-18-2013, 06:54 AM
Plain Old Member
Don't think it's there. I think the F53 class a chassis was the same way if I remember right, but hadn't crawled under one in a while. Not surprising. This has been a topic on several forums and you'll see the same results there, at least on the later models. The older ones did in fact have one on the frame rail under the driver's door. I don't know what year they changed.
05-18-2013, 09:22 AM
That's correct, the filter is in the tank. It also says that in the Ford owner's manual.
05-18-2013, 11:28 AM
I just looked under the drivers door at the frame rail. No fuel filter. There is a section of hose about 4 or 5 inches long with a plastic connector. This short piece of fuel line says "Gas/fuel". Looks like this is where a fuel filter is to be added. But, no fuel filter. Has anyone added a fuel filter here? Thanks for your input, Randy
05-18-2013, 01:37 PM
Why waste your money. Any fuel that gets to that point will have already gone through the filter in the tank.
05-18-2013, 01:52 PM
Phat Phrog Stunt Crew
Found this....
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
05-18-2013, 02:09 PM
Does anyone know at what point should the in tank fuel filter be changed? Or never?
05-18-2013, 08:50 PM
When it plugs up and the engine stops!! Manual basically says it should never need changing but I guess if you got to 100K miles maybe you should. My experience with every EFI Ford I have owned (four) is that the fuel pump fails by 100K so it can be changed then as it is part of the fuel pump assembly.
05-18-2013, 09:26 PM
Good to know, thanks for all the info.
05-19-2013, 12:40 PM
Fuel Filter
Your Filter is located in the Fuel Tank I believe. (99.5%) sure.
At any rate, the filter is good for at least 100,000 miles.
Any Ford (or Chevy) dealer will be able to tell you for sure.
