Old 09-13-2018, 05:08 PM   #1
While Crawling Under Motorhome
Noticed a long crack on the fiberglass underbelly. Not happy about this. Not sure if it warrants repair or not.
ID:	186387Click image for larger version
Kim
bayoubelle is offline   Reply With Quote
Old 09-13-2018, 05:48 PM   #2
Total Loss's Avatar
I would at least caulk it and watch it. If it splits the caulk or cracks worse, I would grind it down and layer some fiberglass and resin over it. Looks won't matter since it is on the underside.
My $.02
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 09-13-2018, 09:07 PM   #3
Per my conversation with various managment and service folks at the factory. That layer is only a vapor barrier. It was suggested to seal the crack with eternabond tape or similar.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is online now   Reply With Quote
Old 09-14-2018, 12:13 PM   #4
It doesn’t look like the crack goes all the way through so I wonder if necessary to seal it. If water splashes from the road and some gets through would it get to the flooring?
Kim
Old 09-14-2018, 01:15 PM   #5
You might want to drill a small hole on each end to help keep it from spreading, then eternabond tape. Keep an eye on it.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 09-14-2018, 02:43 PM   #6
SailorSam20500's Avatar
Adding small holes at each end to keep from spreading is a good idea. Eternabond or Flex Tape over the crack will keep dirt and water from getting into the crack. Dirt in the crack when it flexes will slowly make the crack larger. Even if not all the way thru, water can migrate thru the crack and will enable further deterioration of the fiberglass.
As noted, putting a fiberglass patch over the crack is the best solution - but is more work and cost. I never enjoyed working on fiberglass over my head...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 09-16-2018, 08:09 PM   #7
Picked up a 6’ strip of Eternabond from dealer will apply when weather cools a bit. Thanks for all suggestions.
Kim
motorhome
