Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-07-2018, 10:25 PM   #21
Originally Posted by GigSeeker View Post
I'm confused about this. Our 2500TS panel has modes for heat and cooling, and a separate furnace button. If I select heat and not furnace am I burning propane anyway? If not what is providing the heat source?
I don't know what is in your trailer. If you get heat from the ceiling you have a heat pump system. It is using the ac in reverse cycle to produce heat. You are not burning propane. Below 32 degrees F outside temp, your heat pump will not provide heat. It will require AUX heat. It will shut off your compressor and turn on your furnace. Now you are burning propane. You will burn propane if you hear the furnace and feel heat from the floor.
Old 02-08-2018, 11:07 AM   #22
Certified Curmudgeon
Duckogram's Avatar
Trailer! We don’t got no stinking trailer. J/K Seriously, as UTGrandpa mentioned, the issue is heat source in temps where the heatpump does not function. I see this as; Save
a couple if gallons of propane and maybe spend hundreds, maybe a thousand to have your tanks, water pump and plumbing replaced.
Ducky Sez; My posts are intended to help with technical and maintenance issues for F/SS only*. I do not measure skin thickness and nice is just another four letter word.
Duckogram is online now   Reply With Quote
Old 02-08-2018, 11:22 AM   #23
cavie,
We've discussed this before...
There are three standard types of heat systems that could be available in most travel trailers/5th wheels/pop-ups/a-frames. (NOTE: I'm not including the hot water systems used in some motorhomes but not all)
There is a Heat Pump, where the A/C compressor runs backwards to create heat and blows out of the A/C vents.
There is a Heat Strip that is sometimes an option on A/C units. It uses an electric heating element to create heat and blows out the A/C vents.
And finally the propane furnace, which blows heat out the floor vents.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 02-08-2018, 11:32 AM   #24
cavie,
You are 100% correct. I try to avoid the heat strip discussion because it is rare and muddys up the conversation.
furnace, pump
