Old 03-02-2015, 09:25 PM   #1
rbetzwieser's Avatar
Winegard sensar powered?
I have a 2014 3050s with the winegard sensar antenna. I was wondering if the antenna is powered or not. Every other camper I have owned had a "booster" button for the antenna. Have not found this on the unit. I just bought a King Jack retrofit antenna and plan to install it in the spring. This antenna needs power through the coax that's why I am asking. Thanks.
rbetzwieser is offline   Reply With Quote
Old 03-02-2015, 10:10 PM   #2
Boso's Avatar
Button over drivers side above bunks best seen when on bunks or stool also button on antenna at ceiling or it is in my 3050s 2015
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 06-18-2015, 09:48 PM   #3
I have a 3050s sunseeker and I've been told it's hardwired for power. There is no push button anywhere. If you look at the switch box (controls tv ant/aux/etc...) there is definitely a electrical wire going into the back. So I have to assume that is how it's getting power when you push the antenna option. I'm also thinking about buying the jack antenna to replace the existing antenna. Yes it says it needs power. There is a red light on the bottom of the antenna, so when I get it and install it I will be able to see if it's getting power.
johnlantz is offline   Reply With Quote
Old 06-19-2015, 04:34 AM   #4
johnlantz I already installed the jack antenna on my 3050s. You are correct, the switch box gives it power. No push button. Not sure it made a difference but it looks cool!
Old 06-19-2015, 06:24 AM   #5
Witch Doctor's Avatar
Have you tried your cable yet. I know if my plate has power, I can not get cable TV with it on, unless your cable is wired to a different location, just wondering.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-19-2015, 10:59 AM   #6
Cable works just fine.
Old 06-20-2015, 05:19 AM   #7
Outlaw7's Avatar
I replaced the Sensar on my 2014 3050 with the new Winegard Rayzr. My 3050 doesn't have any booster button that I know of. I just crank up the antenna, do a channel scan, and so far so good Click image for larger version
Name:	ImageUploadedByForest River Forums1434795574.162308.jpg
Outlaw7 is offline   Reply With Quote
Old 06-25-2015, 09:49 PM   #8
Yes I installed the replacement head last weekend. My 3050s does not have a button to push. I confirmed the connection in back of the box is providing the signal boost. While plugged in the light is red. Pulled out the connection and the light goes out.
The new antenna did make a difference. I still have to rotate but I am finding a few more stations. One position of the antenna won't find all the channels.
Old 07-18-2015, 12:24 PM   #9
MSGCOONS's Avatar
Send a message via Yahoo to MSGCOONS
Does anyone have any manuals for the push button box. Lots of cables and one power connection. Had three setups for different locations.
MSGCOONS is offline   Reply With Quote
Old 07-18-2015, 12:46 PM   #10
Flybob's Avatar
Power is supplied via the two power wires coming into the push button wall plate. It is then routed to the antenna thru the coax that goes to the antenna.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
power, winegard
