Old 06-09-2013, 08:53 AM   #1
Wing Wall Oak MDF
Does anybody know where to find the material used for the little partition walls located just behind the driver and passenger seats on the 2005 Sunseeker? Each little wall extends from the floor to just above the cabover floor holding the mattress in. The material is 1/2" MDF with a photo light oak finish on both sides.
J2Davis is offline   Reply With Quote
Old 06-09-2013, 03:41 PM   #2
Motorized GM
Be hard to find now. We wrap those in vinyl now. Might want to look at that or use stained hardwood.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-09-2013, 07:45 PM   #3
Can the vynl be ordered? Maybe I can repair the part of the MDF that is bad then cover the entire wing with the oak vynl.
Old 06-09-2013, 07:47 PM   #4
Motorized GM
You could probably order some through the dealer, but you'd probably be better off sourcing something locally. If you don't have it now...then you can pick something that matches what you want it to. or just overlay the wing wall with stained plywood.
