Originally Posted by Forester1966
I am getting ready to winterize my 2017, 2861DS. This is my plan.
1. Drain the black water, gray water, and fresh water tanks.
2. Then drain the hot water tank.
3. Now select the hot water bypass valve to allow water to bypass the hot water tank (where is the bypass valve located?).
4. Then put the suction tube in the gallon of RV antifreeze, turn on the freshwater pump (do I bypass the fresh water tank too?).
5. With the pump on open the faucets and shower and toilet one at a time until the pink flows thru! Now I should be winterized, is that right?
Yes - and don't forget the outside shower if you have one. I do not put antifreeze in the FW tank.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
