Old 11-11-2018, 06:51 PM   #1
Winterizing 2019 3010ds
Hello
I just purchased a 2019 forest river sunseeker 3010ds. We are winterizing the unit and i was wondering if there was a low point drain and a water heater bypass for the unit? And if so where would they be located?
Michael
2019 Sunseeker 3010ds
SunseekerFAMof6 is offline   Reply With Quote
Old 11-11-2018, 07:26 PM   #2
Low point hot and cold behind passager side dullys . Water heater bypass valves under kitchen sink cabinet , front panel with 4 screws on cabinets fronts will get you to them .
fred+sherry is offline   Reply With Quote
Old 11-11-2018, 07:30 PM   #3
Thank you so much for the help!
Michael
Old 11-11-2018, 07:41 PM   #4
Bill and Gail's Avatar
The one low point drain has a cap (whatever you do, don't lose the special washer), the other has a valve, in by the water pump, filter area.
Bill and Gail is offline   Reply With Quote
Old 11-11-2018, 07:53 PM   #5
Thank you!
Old 11-12-2018, 09:11 AM   #6
I found the low point drains. Only the red pipe had a threaded cap the blue did not. Is this normal? Thanks in advance Click image for larger version
Old 11-12-2018, 10:48 AM   #7
Shredder's Avatar
Yes that is normal. You unscrew the cap to drain the hot. For the cold you open the compartment where your water filter is you will see a vale. That one is for your cold water.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 11-12-2018, 07:47 PM   #8
It will also drain fresh water tank . With the valve open . You picked a great floor plan . We enjoy ours
Old 11-12-2018, 07:52 PM   #9
Don't forget to remove the water filter.
Old 11-12-2018, 07:55 PM   #10
Thanks everyone for your responses. I appreciate it being a newbie!
Old 11-13-2018, 08:12 AM   #11
Chief tinkerer
Gidyupgo's Avatar
....... and blow out the ice maker line if you have one by cycling the ice maker with air connected. This keeps the valve in the outside fridge panel from freezing. Most people try not to pump pink into the ice maker. Push pull cutoff is under the fridge, access by removing 4 screws and removing the rectangle wooden panel. Close it after you blow it out and before pumping pink. Instructions for manually cycling I've maker is on a sheet under the snap-on end cap of the I've maker housing. 110v will have to be on. Cycle it until just air comes out, then close the shut-off. There is also a way to connect 110v directly to the valve outside to cycle it if you prefer.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 11-13-2018, 11:57 AM   #12
DW's 401(k) Plan
DaGrinch's Avatar
You know, Gary, you've helped so many of us out with this, you should make and post a video on YouTube!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 11-13-2018, 08:30 PM   #13
Garrette's Avatar
Additional thoughts, after you have finished, unscrew the water filter housing and leave it off. Any amount of moisture in the threads can freeze and crack the housing.
Unscrew the lines from the water pump and drain them as well and the small filter. Before the pump. On the small filter, unscrew the plastic cap and clean it out.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-15-2018, 08:10 AM   #14
Chief tinkerer
Gidyupgo's Avatar
Thanks, maybe
Gary
winter
