Old 11-13-2014, 09:53 PM   #1
Frankie Z's Avatar
Winterizing by pass valve question
While reading the recent post concerning winterizing hot water heater I noticed the advice was to turn all 3 valves 90 degrees. This was my first time winterizing and I only turned 2 of the valves. The hot and cold. When I ran antifreeze through the lines pink antifreeze came out of all faucets. Does this mean my bypass was open all summer? If so Is that possible and still have hot water delivered to faucets during camping season? There is no water in water heater so I know input line was closed. Is there anything I need to do to avoid any winter problems?
Frankie Z is offline   Reply With Quote
Old 11-13-2014, 10:11 PM   #2
Yes, but the hot water won't be as hot.
Did you open the hot faucet only to run the antifreeze through?
In the summer, the cold and hot are open and the center line (bypass) is closed.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
hockeytownmom is offline   Reply With Quote
Old 11-13-2014, 11:04 PM   #3
Frankie Z's Avatar
I opened hot water faucet only to run antifreeze through.
Thanks for your input
Old 11-13-2014, 11:11 PM   #4
Herk7769's Avatar
Here is how a 3 valve system is set up. Not my graphic; but it is awesome.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 11-13-2014, 11:26 PM   #5
Did you drain the water heater?? Make sure the bypass is like the lower picture in Herks attachment. If its not, water will sit on the valve and freeze and crack the valve.
Hindsight is 20/20 !!
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 11-14-2014, 07:02 PM   #6
Frankie Z's Avatar
Sorry couldn't open image
Old 11-14-2014, 07:15 PM   #7
BooBoo23's Avatar
Some bypass systems only have 2 valves to turn and have a check valve on the output of the water heater, so you may be OK. Some have only 1 valve. My current RV has only 2 valves, my old RV had 3 valves.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 11-14-2014, 09:03 PM   #8
Herk7769's Avatar
Right click and use "Save Image As"
Old 11-15-2014, 08:47 PM   #9
Frankie Z's Avatar
Ok thanks
Old 11-16-2014, 03:41 PM   #10
Sunseeker has 3 valves--in, out, and bypass. For winter, in and out should be closed (perpendicular to the pipe) and bypass open (parallel to the pipe).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
winter, winterize
