Old 10-18-2018, 05:53 PM   #1
Hoglou's Avatar
winterizing hw heater
Just a thought. I serviced the hw today and wanted to clean the anode. We leave the anode out after cleaning when the coach is off line and cover the hw opening with a screen. I wanted to soak the anode in CLR but could not find anything other than a zip lock. So I built a little soaker stand to cover the entire anode surface and to minumize the fluid they charge so much for..
There is a larger dia hole on the base so the whole tube exits from the bottom.
Haven't figured out how to rotate the pic 90.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 10-18-2018, 05:57 PM   #2
cavie's Avatar
don't know of a reason to clean it.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 10-18-2018, 06:40 PM   #3
WFD
I agree....seems like a unnecessary process.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-18-2018, 06:59 PM   #4
Hoglou's Avatar
muck
Seemed sliimy to me when I pull it, why put the calcium muck back in the water system?
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 10-18-2018, 07:22 PM   #5
Duckogram's Avatar
Slime is bad but its most likely from sulpher (hydrogen sulfide) which feeds a bacteria that actually grows on surfaces like tan hairy slime. Bleach will kill it.
Have you checked your water heater tank for that slime?
ILB ( | )
Old 10-18-2018, 09:32 PM   #6
I dont think I'd ever clean mine either but I do appreciate your feat of engineering. Thanks for sharing.
Skip12 is offline   Reply With Quote
Old 10-19-2018, 07:19 AM   #7
Shredder's Avatar
I agree its to bad you winterized it already it may have needed a nice run of bleach through the system.
Then again being empty for the winter it will all dry out anyways. Just make sure that you do a good sensitization when you bring it back out.
Other then that i just leave them till there is almost nothing left then i toss and buy a new one.
Bob
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 10-21-2018, 11:26 PM   #8
Garrette's Avatar
I clean mine also, just use a fine grit sandpaper.
Hog, if I ever break down, I want it to be near your house.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-22-2018, 11:29 AM   #9
Hoglou's Avatar
repair not needed
We drain and clean the water systems each time we get home. We are not winterized, in fact at least two more trips remain on the 18 schedule... I 'm the guy who services and washes the road trip car after each trip ready for a short notice launch. Now if I kept my boots by the bed that may be a bit much.. but DW makes me keep them in the laundry room, she just dont get it.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
heater, winter
