Originally Posted by 5picker
You seen the photo and I didn't but the white flex line you describe in the wet bay with a cap is 'typically' the line used to pull in antifreeze. It is not a low point drain.
5picker, you may be correct. Then that would mean the rigid blue line with the valve empties all low point drains as well as the fresh water tank or it empties just the fresh water tank and there's a low point drain elsewhere - which I suggested the OP look for.
From the pictures received, I could not identify a connection from the flexible white line to the water pump suck side for antifreeze. I'll look again though.
The screw on cap on the flexible white line is the same style screw on cap as I have on my Sunseeker low point drains so I thought having that in common made sense to identify it as such.
Sent from my SM-A505U1 using
Forest River Forums mobile app
