Originally Posted by Sunseeker16
Preventable is a premature assumption unless you know something. With NTSB involved there shouldnt be any conclusions released unless they do it and it's way too early for conclusions.
As it turns out, this rail system has a low-voltage rail-break notification/protection system meant to notify the operators if there is rail damage. It, too, was not working or ignored.
As for the bridge damage, it was collateral damage caused by heavily-loaded rail cars piling up on and crashing into the bridge structure. There's no evidence that the bridge made any contribution to the accident...other than collapsing under the onslaught of derailed coal cars.
"Investigators are working to determine the cause of the broken rail and why warning systems designed to alert the crew to the track condition failed. "
https://www.cpr.org/2023/10/17/puebl...idge-collapse/
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of
Lake Vallecito
