Old 10-16-2023, 07:29 PM   #1
I-25 closed due to train derailment
Both directions clised at Pueblo.
https://www.cbsnews.com/colorado/new...rth-of-pueblo/
Semi driver killed so investigation and cleanup can take a while. CSP is advising "extended closure".
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 10-17-2023, 05:13 AM   #2
It sure looks like it will take a while to get this cleaned up. RIP to the poor truck driver. Wrong place at the wrong time I guess.
Glen & Lee
Cleveland, GA : Rochester, NY
2019 Primetime Sanibel 3851
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 10-17-2023, 07:38 AM   #3
Retired Georgia Rally
aceinspp's Avatar
Be interesting who is the owner of the bridge. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 10-17-2023, 07:45 AM   #4
Looks like BNSF Railway.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is offline   Reply With Quote
Old 10-17-2023, 10:09 AM   #5
seems this happened over a week ago. guess it was sunday i read this seems like a week all ready
MR.M is offline   Reply With Quote
Old 10-17-2023, 10:26 AM   #6
A little irony. The Transportation Technology Center (TTC) is located in Pueblo where they study effects of wear on train components and infrastructure.
Apparently this bridge was overlooked.
Old 10-17-2023, 10:48 AM   #7
Could be a bridge issue could be equipment failure that caused the bridge to fail. Most bridge failures are caused by the derailment rather than the derailment caused by the bridge failure but it does happen. I'm familiar with the area as it was in my district of responsibility before I retired from the agency with railroad regulatory oversight.
Will Rogers
Old 10-17-2023, 01:18 PM   #8
Update:
Authorities have now stated I-25 will remain closed "for the foreseeable future".
Ugh!!!
Old 10-17-2023, 01:40 PM   #9
BROKEN RAIL: https://www.denverpost.com/2023/10/1...ken-rail-ntsb/
This will be very expensive for the owner of these tracks. The list of potential litigants is VERY long. And it was preventable.
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 10-17-2023, 02:02 PM   #10
aceinspp's Avatar
There is a dispute as to who owns it state or RR. Later RJD
Days camped 2019 62
Old 10-17-2023, 02:04 PM   #11
aceinspp's Avatar
Was not over looked inspections must be conducted annually Later RJD.
Days camped 2019 62
Old 10-17-2023, 04:09 PM   #12
One might ask if an annual inspection is enough on a 60+ year old RR bridge. Especially one seeing mile-long coal trains at least daily.
Also worth asking why the equipment supposed to detect rail failure didn't.
Old 10-17-2023, 05:24 PM   #13
Preventable is a premature assumption unless you know something. With NTSB involved there shouldnt be any conclusions released unless they do it and it's way too early for conclusions.
Will Rogers
Old 10-17-2023, 06:33 PM   #14
Seņor Member
ForestWalker's Avatar
As a retired track inspector I agree.
2017 Forester
3051S "Bluga"
ForestWalker is offline   Reply With Quote
Old 10-18-2023, 07:51 AM   #15
aceinspp's Avatar
Bridge may be old but they where always over built to handle the days of steam. There is no detector track side for broken rails only for hot box dragging equipment detectors. BTW this is signal territory had a rail been broken prior to derailment train would have had a red signal and stop prior. If it is truly a broken rail then it most likely broke under train while moving which occurres at times. Railroad does ultrasonic testing of rail at least yearly. Later RJD
Days camped 2019 62
Old 10-18-2023, 07:53 AM   #16
aceinspp's Avatar
So true also other factors can be considered such as broken axle or wheel. Later RJD
Days camped 2019 62
Old 10-18-2023, 09:05 AM   #17
Typical wreckage pattern for broken rail or car component failure. Poor trucker never stood a chance.
Will Rogers
Old 10-18-2023, 11:58 AM   #18
Bridge may be old but they where always over built to handle the days of steam....
Bridge was built when the interstate was constructed in the 1960s. Records are being checked to see whether State Dept of Highways or Santa Fe Railway built the bridge.
Old 10-18-2023, 12:41 PM   #19
My prediction --------
Old 10-18-2023, 06:52 PM   #20
aceinspp's Avatar
Attachment 294212
Ya right. Later RJD
Days camped 2019 62
