Old 02-27-2020, 11:24 PM   #1
West Yellowstone South on 191 - RV Trip Wizard question
I am using RV Trip Wizard planning our trip from California to Iowa. Heading up to Yellowstone and am trying to get RV Trip Wizard to route me down 191 to 26 but it won't let me.
I have a 2019 Forest River FR3 33DS and will be towing a Buick Envision. Total Length about 45' or so.
I remember driving that route in August of 2018 but was using a small Buick Encore driving my daughter back to school.
I don't remember any issues with the road so I'm not sure why RV Trip Wizard won't route me that way.
Any thoughts on why it won't route me or known issues with 191 through Yellowstone with my size rig..??
David
ehlerts01 is online now   Reply With Quote
Old 02-28-2020, 09:13 AM   #2
SeaDog's Avatar
do a quick google search for length restrictions along the route that may be the reason this is just a guess on my part.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-28-2020, 09:45 AM   #3
ManlyMan's Avatar
I'm not familiar with RV Trip Wizard but I know some software has a setting that avoids "toll roads." Since you have to pay to enter Yellowstone, most trip software considers that as a toll road. You might check and see if your Trip Wizard is avoiding tolls. Just a thought.
I AM A SEER OF ALL THINGS.
"The only true wisdom is in knowing you know nothing."
ManlyMan is offline   Reply With Quote
Old 02-28-2020, 10:25 AM   #4
dougschne's Avatar
David
I'm having the same issue with RV Parky, a very good planning software, and from what I can figure out is that roads are closed this time of year in Yellowstone. I cannot find any lenght or height restrictions on any of the major roads thru Yellowstone. Many RVs go from West Yellowstone to Cody every day. Just know the roads are there and check to see id there open when you want to go thru.
2014 Sabre 33CKTS purchased 01/18
2009 Ford F250 SD 6.4L TD "FrankenFord" No Longer
2019 Ford F350 Lariat SD, 6.7 TD
Check out my Blog "A Grande Tour" about our travels and other writings! agrandetour.com
dougschne is offline   Reply With Quote
Old 02-28-2020, 01:48 PM   #5
Telstar's Avatar
It may be using current road conditions. 292 is closed until April.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 02-28-2020, 02:07 PM   #6
There are no issues, width or height with that route. I have taken it and my rig is almost 60' overall with a 13'6" height. As others have pointed out 191 through Yellowstone is closed until spring so most routing software will take you around it.
2015 Ceder Creek 38FB2
2016 F350 Dually Diesel
srosey is offline   Reply With Quote
Old 02-28-2020, 03:10 PM   #7
Why don't you just message trip wizzard . they always answer my questions
jgiarrus is offline   Reply With Quote
Old 02-28-2020, 08:42 PM   #8
Bluepill's Avatar
As long as 191 is open to traffic, no problem with a large rig. Expect to see some snow even in Summer at the crest.
Old 02-29-2020, 07:51 AM   #9
RV Parky trip
Try adding a stop inside Yellowstone and see if this will pull the route .
Late September of 2019 trip. Yellowstone, Tetons and Grand Canyon. Lots of hills, Buffalo, Elk, Moose.
Woody & Cookie
2017 Coachmen Micro 20CB (Livy)
2015 Smart Fortwo (Huck)
New Hampshire
Wood2Cook is offline   Reply With Quote
Old 02-29-2020, 04:49 PM   #10
Iggy's Avatar
Don't sweat it. All those roads are fine.
Been on them in my motorhome plus car.
This is the route I see.
2012 Georgetown XL - 378TS 73K miles
Life is a journey, not a destination
Old 03-15-2020, 09:16 PM   #11
Garrette's Avatar
Bring up your map, highlight the route in question and use the drag function located in the upper left of the screen. You will be able to drag that leg to the route you want.
Everyone is correct, the 191 is a beautiful route. We took it last year in our 32 class C with toad and it was beautiful in the early morning. Easy drive. Hope this helps.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 03-15-2020, 11:50 PM   #12
I found out what the problem was. I kept looking at my default settings and not my trip settings. I found that I had RV routing and not Standard Routing turned on. Once I changed it to Standard, then I could route through Yellowstone.
All is now good with my trip. Can't wait to leave on July 15th..!!!
