35' Trailer - FL to ND, MT, WY, SD, AR And Return
I pulled a 35' trailer from Florida to Teddy Roosevelt, Glacier,Yellowstone, Grand Teton, Custer State Park, Wind Cave NP, and back east to FL. Not a problem with the length of the trailer in the campgrounds. I used the RV Life app which allows you to filter campgrounds based on trailer length, hookups and other criteria. You will be fine with a bit of planning. My most difficult area was gas stations because I have a gas powered crew cab truck and when connected to the trailer I am a little over 60' in length. Gas stations are designed for auto mobiles and regular pickups. Just shoot for the outer most island of pumps and be prepared to wait for gaining access as well as the people who will pull in front of you to gas up, not realizing the off-tracking on your rig is like 8 feet. Meaning the trailer axle will swing an arc with a radius of 8 feet less than your truck, so you have to do some creative manuevering when you pull away from the pumps that your trailer doesn't drag the pump with its rear bumper.
