Old 07-22-2018, 11:04 PM   #1
12 volt front windshield shade
I have a 2012 Georgetown 329ds. The front window shade is acting up. When I depress the switch to lower the blind there is a very low beep sound coming from the shade and then the shade goes down about 8 inches and stops. To bring the shade lower I must depress the button again for it to lower another 8 inches. Its the same procedure to raise the shade and sometimes nothing happens. Its seems like the motor is not getting the correct voltage, or is going bad. But I am not sure. Maybe need to replace the shade. Any suggestions?
pact40 is offline   Reply With Quote
Old 07-22-2018, 11:28 PM   #2
No it sounds like you need to reprogram it.
This happens when a battery is disconnected or something.
Here is the programming instructions.
You should have some instructions for it if you bought it new.
Good luck
File Type: pdf Privacy Shade Programming Instructions.pdf (92.2 KB, 181 views)
Old 07-23-2018, 05:28 AM   #3
Thanks for your quick answer. You are probably right. I did pull the battery terminals off to clean them the day before the problem started. I have one more question. Do you know where the setting key is located ? I haven't been out to look just yet in the rv.
Old 07-23-2018, 07:18 AM   #4
bubbles's Avatar
It should be stowed up at the left end of the shade roller with the power wires.
Old 07-23-2018, 08:16 AM   #5
Last time I checked it was tucked behind the plastic vertical pillar cover at the top drivers side.
Old 07-23-2018, 09:02 PM   #6
Wow, thank you Iggy. Or salesman told us we could lower the front shades partially while driving to act as a sun shade. When it didn’t work that way I assumed it was just another case of salesmen not knowing what they were talking about.
I reprogramed the shades according the instructions you supplied and they work as they should have. Also, I too found the key(button) behind the plastic cover on the left side of the windshield.
Brinkmef is offline   Reply With Quote
Old 07-23-2018, 09:36 PM   #7
camaraderie's Avatar
Nice solve Iggy/Bubbles...I learned another thing today! Thanks.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 07-23-2018, 09:50 PM   #8
Glad things worked out.
Glad to help.
Old 07-24-2018, 12:20 PM   #9
Hi Iggy,
You are a great source of information! Thanks for taking the time and making the effort to share the information that I am sure you spent many hours collecting.
Safe travels,
John
Outtahere100 is offline   Reply With Quote
Old 07-24-2018, 05:48 PM   #10
Originally Posted by Outtahere100 View Post
Hi Iggy,
Safe travels,
John
You need anything other than money just ask me.
Glad to help out.
12 volt
