02-14-2016, 08:59 PM
2 problems 2007 Georgetown XL
I just purchased a 2007 Georgetown XL 378. I have two major issues. The first is that when put into park, I cannot shift out of park, unless I turn the engine off.
The second is that the coach list to the passenger side 2-3 inches.
Both are a royal pain.
Any ideas, thanks.
02-21-2016, 07:40 PM
Your first problem I would talk to Ford. Your second I would talk to Ford since I had the same problem on a new XL coach and they replace the right rear spring-leaf. Solved problem two.
Denis, Forest river Georgetown XL 377 2015, towing a 2014 Ford Explorer XL
02-21-2016, 08:47 PM
Make sure you have Brake lights when the brake pedal is applied, there is a small solenoid on the column that allows the gear selector to be pulled from park when the brake pedal is pushed, if you have brake lights, I would say the brake switch is ok and it could be the solenoid itself on the column. Check fuses....
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
02-21-2016, 11:41 PM
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Were you stepping on the brake? Not trying to be smart.
George & Jerri
06 GT 340 TSSE
USMC
02-22-2016, 10:01 PM
Not exactly sure what your asking? Your supposed to push on the brake pedal to get gear selector out of park if the key-is on, OP stated he can get selector out of park of ignition is off.... So I was just trying to confirm if he has brake lights, that would help eliminate brake pedal switch etc.... Process of diagnosis...
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
02-22-2016, 10:03 PM
This isn't my issue, I was merely trying to help someone that is having an issue.... But thanks for the helpful insight!
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
02-22-2016, 10:06 PM
Stepped on the break. It works with ignition off. Thanks.
02-22-2016, 10:08 PM
Do you have brake lights? Did you check fuses?
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
02-22-2016, 10:13 PM
I haven't had a chance yet, but will do so soon.
I appreciate every ones comments. That is the good part of a forum.
I'm really more concerned about the passenger side being 2-3 inches lower than the driver side.
Again, thanks, all.
02-23-2016, 11:37 AM
I believe the rear suspension has a spacer under the left rear spring that raises that side higher. It was installed for another application but was never taken out for this application. I have a 2007 373ds and it leans to the pass. side. I am planning on removing it this spring.
02-23-2016, 11:54 AM
Who Dares, Wins
I have had a few Fords over the years have issues with the park override switch (or something called like it) that keeps the vehicle in park unless the brake is pressed. Needed to put it into neutral then start because it did not require the brake to be pressed to start then shift into drive. I still pressed the brake but the vehicle's would at least get me going.
2015 Chevy HD D-Max
2022 Impression 315MB
02-23-2016, 12:54 PM
I stated the same thing in his other thread that he started.....he will most likely have a 2 inch spacer in the left rear spring....I am finding Forest River to be less than helpful when you question them about anything. I asked about this issue and their wonderful sidewall separation fiasco....no response
02-23-2016, 03:18 PM
Is your passenger side 2-3 inches lower?
02-23-2016, 03:49 PM
Yes, close to 3 inches on the passenger side
02-23-2016, 04:22 PM
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
No that wasn't for you, I used your response and highlighted the area for the op sorry
George & Jerri
06 GT 340 TSSE
USMC
