06-13-2022, 07:41 AM
30 Amp Camp
I am about to set up on a 30A site (I have only used 50A before) for a couple of family members that are visiting for a few days.
It’s my assumption that I will only be able to run 1 of the AC units (I think the dealer advised me of this, but not sure).
Is this the case? It is safe to assume that one TV and a few DC lights will probably be turned on most of the time…
Georgetown 31R5.
06-13-2022, 07:45 AM
Part-Time Campground Host
You are correct in your assumptions.
TV, a few lights, and ONE AC. If you try 2 ACs you will probably trip the pedestal breaker.
Craig & Cath
Days camped since 2015(retirement): 1687
06-13-2022, 07:46 AM
Insert witty title here
Yes. One AC, some lights and a TV are about all you can run at once on a 30A site. You may even have to go as far as turning off the AC to run the microwave or any other high current appliances such as electric heaters and hair dryers.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
06-13-2022, 07:51 AM
DISREGARD THE FOLLOWING but leaving the post so the subsequent replies make sense...
If you've got a regular household 15 or 20 amp outlet near the 30 amp, you can use one of these dogbones to increase your available amps. But you'd probably be pushing it to try to use both A/Cs.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
06-13-2022, 08:20 AM
PopFla, we have discussed these so called "cheater" adapters as you posted several times before. The literature with them will state that they will not work with a GFCI outlet (this has to do with the shared neutral between the two cords feeding the 50 amp part). The problem is, that by code, most 15/20 amp outlets you will find outside and/or at a campground pedestal will be the GFCI type...thus this cheater adapter will not work. Just letting you know.
EDIT: I looked up the same site you posted. You can see at the bottom of the description it does not work with GFCI Outlets.
2011 Flagstaff 831 RLBSS
06-13-2022, 08:41 AM
In addition to Wmtire's comments, it is very probable that the wiring to the pedestal is protected upstream by another 30A breaker in a locked location. If that is tripped by using more than 30A at the pedestal, it could be a problem especially if occurs after hours as it may not get reset until the next day.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-13-2022, 08:43 AM
Try using propane to heat your water rather than the electric. That will help. Maybe turn off the air while you are using the microwave.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
06-13-2022, 09:37 AM
Points taken, gentlemen. Disregard my post about this adapter.
But just an FYI - - I have stayed at several older campgrounds where the 15/20 outlet has not been GFCI protected although I agree it should be.
06-13-2022, 03:13 PM
Thanks for confirming what I belived, folks.
