Old 11-13-2020, 03:49 PM   #1
30 AMP Power
I have a 2017 Georgetown. I am hooked up to a 30 AMP outlet. This morning we overloaded the 30 AMPs and everything went out except that running off the batteries. At first I thought it was the GFI outlet but then realized I was not getting any power through the Electrical system.
I cannot figure out what the issue is. Any thoughts.
bmoehler is offline   Reply With Quote
Old 11-13-2020, 04:13 PM   #2
Step 1. Check the main breaker in your power control box. Cycle it off then on. If no power go to next step.
Step 2. Check the breaker in the power pole. Cycle if off then on. If no power go to next step.
Step 3. Shut off the power pole breaker and disconnect the power cord from both the pole and RV. Inspect the plug ends for obvious signs of burning. If burnt DON’T attempt to use that cord, it is trash. If it looks ok then you should break out your trusty multi meter and start checking for power at the pole then the cord, etc. If you don’t have or are uncomfortable with a multi meter seek help from fellow campers.
Good luck.
WanderMore is offline   Reply With Quote
Old 11-13-2020, 07:58 PM   #3
Kanadian Kamper
kenandterry's Avatar
Good luck.
Pretty much covers it.
Ken and Terry
2018 Sunseeker 2430S
and might rarely get pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 11-13-2020, 08:15 PM   #4
Flybob's Avatar
Items to check are listed above. 30A is not much so you will need to manage power usage.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
power
