Previously, I replaced my overhead A/C filters by cutting down to fit a filter meant for a home unit. Has anyone discovered a better filter alternative?
Just curious. Was there a reason you didn't just rinse out the filters that came with the AC's and keep using them?
Those filters don't work. The inside of my coach is covered with dust. I replaced them with the same filter used in the home but cut down to fit the opening. The dust problem has virtually gone away. I was just wondering if anyone has come across a better idea.
