Originally Posted by fred555
... Is the ABS computer telling the freightliner computer the parking brake needs to be on because the ABS is faulted? There are no faults showing freightliner...weird...confused...no way to read ABS fault
You posted this in the Georgetown forum which does not use Freightliner.
You might get better responses on a different site:
https://www.irv2.com/forums/f26/
If you do not have an account there, create one using the same email address and password as you use here. Both forums are owned by the same company so the software will find your account and streamline the account creation process.
Good luck,
Ray
