Old 06-03-2020, 07:38 PM   #1
Adding fresh water at COE parks
We have july 4 reservations for the week at a nice coe park. It only has 30/20 amp power...no water or sewer. I have a 15 gallon tote to help with the grey tank but no solution for water. I have the side bay with the 3/4 inlet for fresh and will need some sort of pump to fill it. Curious what everyone uses? Looking for a cheap simple solution as most of the time we stay at full hookup sites but will have several family with us this time at a nice lake.
2017 Georgetown GT3 31B3
N Little Rock AR
bclinton is offline   Reply With Quote
Old 06-03-2020, 07:45 PM   #2
Dodge Guy's Avatar
Do they have community spigots throughout he campground? If so how far are you from the closest one? Me and my buddy put all of ours together and filled our tanks when necessary. Probably close to 200 feet.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-03-2020, 08:54 PM   #3
I dont think they do. Unless it has changed since 2006 they have a dump station at the entrance with fresh water fillup too...
N Little Rock AR
Old 06-03-2020, 09:21 PM   #4
If they have a fresh water fillup, you should be able to use that to fill your fresh water tank. We don't have your rig, but most have a valve that you turn to put fresh water into the fresh water tank. Or am I not understanding your question?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-03-2020, 09:45 PM   #5
I installed a pump from harbor freight in the compartment next to the fill It pumps 3 gallons per minute. I ran a 12 volt power source to the pump with a switch on it so I can easily turn it on and off and installed two short hoses on the pump. one that will reach a five gallon water jug and the other that has a hose connection that goes into the fill port. It makes it very easy to fill my tank back up.
DaveandChris is offline   Reply With Quote
Old 06-04-2020, 12:48 PM   #6
frozen's Avatar
I carry water from a hydrant in a 6 gallon jug, then use the RVs pump to draw it in though the winterization hose. Takes about one minute per gallon.
frozen is offline   Reply With Quote
Old 06-04-2020, 01:00 PM   #7
n0ms's Avatar
I have used a fitting called a Water Bandit. It lets you fill from any faucet. I also am set up to fill the fresh water tank with the antifreeze hose.
The antifreeze hose goes in the 5 gal water jug. The RV pump it into the fresh water tank. Just like frozen's post.
n0ms is offline   Reply With Quote
Old 06-04-2020, 01:31 PM   #8
Dahagen
What Dave and Chris said. A cheap pump from Harbor Freight. Also, fill before leaving home, or fill at the sewer dump on the way in the park.
dahagen is offline   Reply With Quote
Old 06-04-2020, 01:43 PM   #9
360true's Avatar
Suggested tip
I too use the winterization valve to suck water from a collapsible 5 gallon jug. But i also connected my outside shower to the fresh fill port, using a couple plastic plumbing adapters. I open the winterization valve, connect the shower to the fresh water fill and turn on the shower faucet. It draws water from the jug and pumps it into the fresh water tank.
ID:	230692   Click image for larger version
360true is offline   Reply With Quote
Old 06-04-2020, 01:49 PM   #10
Dodge Guy's Avatar
Has anyone added an extra tank under the RV in between the frame rails just behind the fuel tank? I was thinking about doing this! Maybe a 55 gal blue potable drum? Extra water would be nice for extended dry camping!
Old 06-04-2020, 02:05 PM   #11
360true's Avatar
Watch your weight.... 55 gallons of water weighs about 450 pounds!
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
Old 06-04-2020, 02:28 PM   #12
djemgoss's Avatar
adding fresh water at COE parks
I bought this pump at Harbor Freight (https://www.harborfreight.com/12v-dc...=transfer+pump). It $50 dollars, but they always have a 20% off coupon in one of their flyers or on line.
I mounted it to a board and bought some plastic tubing and fittings and pump it out of my (2) 5 gallon water jugs into the fresh water tank. Fast and easy on the back!
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 06-04-2020, 02:33 PM   #13
What do we do?
What only use campgrounds with water, electric and sewer.
Old 06-04-2020, 03:42 PM   #14
Thumbs up water pump
Sweet idea! If falls into the KISS (keep it simple stupid) category. Thanks.
kszac is offline   Reply With Quote
Old 06-04-2020, 04:01 PM   #15
Aw......neat idea. So you have no issues with priming? I might just do that.
N Little Rock AR
Old 06-04-2020, 04:24 PM   #16
I went to Tractor Supply and bought a 30 gallon tank that is suitable for drinking water and a pump from Harbor Freight. I mounted the tank in the truck. It's very easy to fill and I don't have to do any lifting.
I also bought a macerator pump and a used 55 gallon blue barrel. I built a rack to sit in the back of the truck and strap both tanks to it. I can empty the gray water tank and fill the fresh any time I want to.
Willie
Old Willie is offline   Reply With Quote
Old 06-04-2020, 05:23 PM   #17
If your really looking for cheap you can buy a hand pump sold at rv supply stores that are used to pump antifreeze in to the water inlet. It has a male hose end. To winterize it will suck a gallon jug of antifreeze dry in about 6 or 7 pumps.
markb422 is offline   Reply With Quote
Old 06-04-2020, 06:38 PM   #18
My sister-in-law can empty my tank with every shower. I bought a 50 gallon water tank that I keep in the back of my truck. I can siphon the water into the trailer (my truck has a 4" lift). If I can't use the siphon, I have an extra Shurflo pump, and can plug it into the truck or the trailer. I have a water thief so I can hook to Forest Service spigots that aren't threaded, to refill my 50 gallon tank.
mnoland30 is offline   Reply With Quote
Old 06-04-2020, 08:35 PM   #19
Adrian Gordon's Avatar
My impression is that the OP is trying to fill his FW tank. Does your FW pump draw water into that tank, or am I misunderstanding?
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
Adrian Gordon is offline   Reply With Quote
Old 06-05-2020, 03:32 AM   #20
Mr. October's Avatar
This is how we did it with our old motorhome too.
Pete Githens
Reading, PA
2019 Georgetown GT5 31R5
2018 Chevy Spark
Formerly - 2007 Itasca Navion (Sold and gone)
Mr. October is offline   Reply With Quote
water
