Old 06-03-2021, 09:14 PM   #1
Adhesive for kitchen backslash
I am needing some suggestions on the type of Adhesive that I could use to reattach the backslash that has come loose. It was held up by something like silicone but at least 1/2" thick.
Will 100% silicone work?
What was used is soft and flexible.
Can y'all give me some ideas.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-04-2021, 08:35 AM   #2
SeaDog's Avatar
Silicone can be used to adhere things. 1/2 thick? does that mean the gap is 1/2 or the bead of the adhesive is 1/2 thick? Is your backsplash molded into the countertop or free to move?
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-04-2021, 10:54 AM   #3
My backslash appears to have the glass affixed to some type of Hardie board then the Hardie board is glue to the wall. The backslash gave way by the adhesive pulling the plastic off the wall. There is a 1/2" gap between the wall and Hardie board.
2008 Honda CR-V
Old 06-04-2021, 11:07 AM   #4
Defiant530's Avatar
We used this product on our kitchen
glass backsplash panel 3 yrs ago and its still stuck https://www.homedepot.com/p/Loctite-...9847/206432098
2021 Riverstone Legacy 39RKFB / 2021 Ford F350 6.7L DRW / 2021 Palomino 2910
Defiant530 is offline   Reply With Quote
Old 06-04-2021, 07:48 PM   #5
SeaDog's Avatar
Are you sure its just the backsplash pulling away and not the countertop moving? if both are moving you may be able to reduce the gap by repositioning the counter.
Retired Navy
Old 06-04-2021, 08:30 PM   #6
I'll check that out. Thanks
2008 Honda CR-V
Old 06-04-2021, 10:43 PM   #7
Liquid Nails
Our glass tile backsplash came clattering down in Cincinnati heavy traffic a few years ago and was very startling. I used liquid nails and that is working.
geoff270ssf is offline   Reply With Quote
Old 06-05-2021, 07:21 AM   #8
Thanks Geoff. I have two glass backslashes and one fell off 3 years ago. I used liquid nail but it came loose at the same time as the other side did this past week. I was thinking maybe something flexible might work better. The main issue I have is whatever adhesive I use it keeps pulling the plastic printed film off of the wall. Now that I am thinking about it, I might add a few large head screws in the wall for something for the adhesive to hold on to. Thanks for making me think. [emoji848]
2008 Honda CR-V
