Your best bet is to replace it with something from a big box or RV store.
If you want to try and fix that one, Pop those caps with the "H" & "C" on them off and there should be screws under them that hold the handles on. Then you can see the stem packing nuts if it's leaking out the packing nuts around the stems you can try to tighten them a little, but be careful.
To remove them the stem will screw out. There are either cartridges or washers in there and you can see if you can find replacements or a washer kit.
Gotta go campin!
