Old 03-14-2018, 08:39 AM   #1
Antifreeze (AF) for 2005 Georgetown
Hello everyone. First time poster. We just recently purchased a used Class A. It is in great condition and we want to use it. I understand the winterization and dewinterization process but not with this coach. We are in Virginia where the weather is all over the thermometer. If I dewinterize, I will have to winterize again but I cant seem to find waterpump are the correct place to introduce the AF. Can I just put it directly into the city water inlet? Will this get AF to the water pump? I have learned so much by reading the forums but could not find anything specific to the 359XL.
Thanks in advance for everything.
BubStine is offline   Reply With Quote
Old 03-14-2018, 08:52 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. To answer your question NO putting AF in the city water connection will not put it in the pump there is a check valve to prevent that consider installing one of these if you don't have it.
https://www.amazon.com/Trailer-CONVE...reeze+pump+kit
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-14-2018, 09:00 AM   #3
Thank you sir. I am looking into one of those Winterizing Kits. I just found the water pump but it has such a small access port, I dont know if I can do this as a DIY project. Wish me luck.
Old 03-14-2018, 09:08 AM   #4
SeaDog's Avatar
the bypass does not have to be installed right at the pump just somewhere in the suction line. It may be that if you follow the pump suction line you will find a space that has room to work.
Retired Navy
Old 03-14-2018, 12:25 PM   #5
RudysWorld's Avatar
On my Georgetown there was a panel over the fresh water tank with 2 small access holes in it to be able to winterize. I removed the flexible panel to be able to access the area better. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 03-14-2018, 03:00 PM   #6
Kanadian Kamper
kenandterry's Avatar
Exactly what RudysWorld said.
My Georgetown had a thin black plastic wall with 2 screw in access doors hiding the fresh water tank and the pump. Also found the in-line fuse for the water pump there. Removing the wall gives complete access to bypass hose for winterizing. I think they install the plastic wall just to protect things from any luggage you might toss in this area.
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is online now   Reply With Quote
Old 03-14-2018, 05:13 PM   #7
On the pax side two access doors from the back is the access. Open the door, slide the plastic panel aft and you’ll see the pump and a plastic clear tube to stick in the jug. To access the water bottle valves lay on your back under the water bottle exhaust panel. You’ll see a white 4” disk like what’s in the shower. Unscrew it and with a flash light you’ll see the red, blue and bypass valve. The valves are white but the pex is colored
Dc8mdtmech is offline   Reply With Quote
Old 03-14-2018, 05:13 PM   #8
Old 03-15-2018, 07:19 AM   #9
As stated above the bypass and siphon line for af is behind the plastic panel in the LP bay. Mine has 2 screw doors but it’s easier to work on by removing the panel. The hot water bypass is under the water heater. Look under and see a screw door.
mypalal51 is offline   Reply With Quote
Old 03-15-2018, 09:06 PM   #10
Thank you all.. Found AF tube attached to water pump. Still new in plastic and zip ties.
antifreeze, georgetown
