Old 12-31-2017, 11:34 AM   #1
Arctic Pac Questions
05 GEO TWN 375 ts
I have an ARTIC Pack what is it anf how do you use it
going to be cold in va
Than you
glenn56h is offline   Reply With Quote
Old 12-31-2017, 11:51 AM   #2
Originally Posted by glenn56h View Post
05 GEO TWN 375 ts
Than you
ArticPack is a supposedly extra insulation package installed in your rig. Don't put too much faith in it.
Old 01-01-2018, 09:58 AM   #3
artic pac how to use?
05 geotwn 375ts
My artic pac has switch on main panel
how do I use it will the tapes? damage empty tanks ?
does it help the freshwater tank?
Thank You
Glenn56h
Old 01-01-2018, 10:53 AM   #4
Dennis King's Avatar
I have a 2017 Georgetown 364ts and the artic pac does great job of keeping inside lines from freezing if you have furnace on . But they say there are places you need to put extra heat like outdoor shower and be sure to disconnect water hose and fill your fresh water tank and empty your black tank and put drains away because they will freeze solid. Others will have much better detailed info but this is what U have read and experienced so far. Good Luck
Dennis King is offline   Reply With Quote
Old 01-01-2018, 10:55 AM   #5
Also I forgot the artic pac I have with the same switch you have has some type of electric strips electric heating the tanks
Old 01-01-2018, 11:00 AM   #6
05 GEO TWN 375 ts
Than you
Aside from extra insulation, you have tank heaters to keep them from freezing. There is a switch someplace convenient to turn them on. Dashboard I assume.
Old 01-01-2018, 02:20 PM   #7
The arctic pac is thermostat controlled and will turn off if temp gets over 40. It also will not hurt empty tanks. When the propane heater is on there are vents that put warm air to the plumbing.
Jim G is offline   Reply With Quote
Old 01-01-2018, 02:57 PM   #8
Just as confused as you
Scrapper's Avatar
Owners manuals say do not use the arctic pac without water in the tanks.
Richard & Jill
Old 01-08-2018, 05:54 PM   #9
Here is the documents I have on the Artic Pak.
Hope it helps and explain how it works.
Old 09-14-2019, 04:13 PM   #10
We may buy a FR C class Sprinter Solera 2015 with the Arctic Pac. Does anyone have any thoughts on how low the temps can get and us still be okay to camp without freezing anything?
Drummergirl8 is offline   Reply With Quote
Old 09-14-2019, 04:33 PM   #11
Arctic Pac. on my 07 never froze while we were at 15 below the only problem was we forgot about the furness we use another heat souse and it kept main heater from coming on as much. So were the heat come from down under to heat water areas gray water and black waster valves froze. We has to use a hair dyer to warm them to open to empty them.If we use the main hear it wouldn't have been a problem'
cfo111 is offline   Reply With Quote
Old 09-14-2019, 09:01 PM   #12
I'm glad that you were able to get out of the jam you were in but it's good to know that you can get out there in the cold. What "07" RV were you in at the time? Was it a Solera or something different?
Old 05-28-2021, 08:41 AM   #13
What should the Arctic Pac switch be set to for normal warm weather please?
JiminFla is offline   Reply With Quote
Old 05-28-2021, 09:08 AM   #14
Kanadian Kamper
kenandterry's Avatar
Think of the Arctic PAC switch as controlling an electric blanket.
Don’t need it ON unless temperature will be freezing or below.
Warm weather camping? Leave it OFF.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 05-28-2021, 09:14 AM   #15
Thanks for the reply. The switch has two positions, ARCTIC and PAC. I don't know which setting is off. Do you know what PAC stands for?
Old 05-28-2021, 09:20 AM   #16
Mr. Dan's Avatar
No... the name of the switch is Arctic Pak and its name is written one word above the switch and one word below the switch. If it were a switch for a ceiling fan, it wouldn't have one setting for ceiling and one for fan.
Does the switch have an internal light? My arctic pak (pack) switch in my Wildcat is not labeled but if I turn it on (switch in up position), an internal light comes on - same as my water pump switch.
Old 05-28-2021, 09:36 AM   #17
Ah so. Got it. Thanks Mr. Dan. Yes the switch lights up in the on position. I was afraid to touch it without knowing anything about it. Very much appreciate the info.
Old 05-28-2021, 09:41 AM   #18
Mr. Dan's Avatar
Now and then, I find my switch on (red light blazing) and discover "one of us" has hit it with an elbow while climbing the 5er's stairs!
