Old 04-01-2014, 12:32 AM   #1
ATF Fluid in Lipperd Slide/Jack Tank
I recently purchased a 2006 Georgtown 36 ft. limited SE. Yesterday I noticed that the fluid in the hydraulic tank of the Lipperd leveling pump for the slides and jacks was about one inch low for ATF fluid. Lipperd recommends ATF with Dexron III or Mercon 5 or a blend of both.
Problem is that I do not know what type of ATF is in there now.
Is there any problem in adding new to the old ATF ?
Thanks--guy
gdwooden is offline   Reply With Quote
Old 04-01-2014, 05:58 AM   #2
No. Use either type. Lippert recommends a 36 month replacement, so you could consider just doing that too.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 04-01-2014, 08:51 AM   #3
jojo bamboo's Avatar
Good advice
suck out the old stuff
and replace with new.
It's a easy job,
and don't over-fill it,
or you'll have a mess when you retrack the
slides and legs
Good luck
jojo bamboo is offline   Reply With Quote
Old 04-01-2014, 09:01 AM   #4
Originally Posted by jojo bamboo View Post
It's a easy job,
slides and legs
Lippert recommends doing a fluid change with jacks up and slides in to maximize the amount of fluid in the reservoir. The little bit left in the jacks and lines will get mixed with the fresh fluid as you operate the system.
Home Port Orlando
Old 04-01-2014, 12:22 PM   #5
Krazymace's Avatar
Originally Posted by Krazymace View Post
This is exactly what is happening to me. Thanks so much. I am still under warranty so will be taking this info to dealer.
You might want to take a look at this.
Krazymace is offline   Reply With Quote
Old 04-01-2014, 12:25 PM   #6
Krazymace's Avatar
Originally Posted by intercept View Post
Attachment 48838
If you still have some creaking they recommend adding more additive.
This is the Lippert blurb.
Here is a supplier for the Maxima,$11.00 a Liter
http://www.jpcycles.com/product/900-553
This is link I meant
Old 04-02-2014, 12:13 AM   #7
Thanks--guy
I use standard original ATF (Type A) as per the Lippert manual.
slide, tank
