Old 06-18-2020, 06:49 PM   #1
Auto leveling jacks
I have a 2006 Georgetown 370XL. I am always convened that when I leave a camp site, the jacks donít retract. Is there a way to manually raise the jacks should this happen?
Thank you to all who help others!
Mark
Markshome2 is offline   Reply With Quote
Old 06-18-2020, 07:36 PM   #2
NXR
NXR's Avatar
Probably. From some searches they appear to be Lippert jacks but it really depends on the precise model. Check here for docs: https://support.lci1.com/documentation/
I've attached the procedure for mine although I do not have hydraulic slides.
HTH,
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 06-18-2020, 08:24 PM   #3
Thank you! This is a start. I have 4 leveling jacks and 3 slide outs. I will need to crawl underneath to check what the motor looks like.
Mark
Old 06-18-2020, 10:40 PM   #4
NXR
NXR's Avatar
My pump is in the same compartment as the house batteries. I would be surprised if the pump was underneath because that would expose it to road debris and water that could damage it.
Ray
Old 06-21-2020, 04:26 PM   #5
Yes. You need a properly sized Allen wrench.
Two preventative things you can do:
1. Ensure fluid level ( and carry spare ATF)
2. Know where the breaker to your hydraulic pump is. Lippert doesn’t know because the electrical is installed by RV manufacturer.
I learned about 2 the hard way.
IDguy is offline   Reply With Quote
jacks, leveling
