Old 02-01-2023, 12:14 AM   #1
Basement door alignment
I know I should know this, but… can the basement doors be aligned? My slam latch doors look like they are unaligned. It’s a 22 36d7 new to me and I honestly can’t tell if they’ve moved or not. Maybe just freaking out for nothing but kinda freaking out. Main one would be the water heater panel on the back passenger side.
Thanks in advance for any help,
Matt
MDow is offline   Reply With Quote
Old 02-01-2023, 06:57 AM   #2
MDow we have a 2022 36K7 and my same panel has moved called FR they said there is a screw that can be redrilled on the L bracket. I looked in the inspection hole where the bypass valve is I could move the water heater. Went to the dealer for them to fix they removed the screw pushed the panel in put the screw back in, is it right I don't know you would think that the water heater would be security in place? Will see what will happen we leave in May and will return home in November.
Tony & Sandy
US Navy 22 Years Retired
Lake City FL
2022 Georgetown 36K7
Teeman is offline   Reply With Quote
Old 02-01-2023, 09:49 AM   #3
bubbles's Avatar
Thanks in advance for any help,Matt
All the slam latch doors can be aligned. Open them up and look at the hinge points where alignment adjustments will be apparent.
Old 02-01-2023, 09:55 AM   #4
Awesome Thank you. I was hoping it would be straight forward. When I can't sit and play with it (stored offsite) my mind just goes to the worst case.
Thanks again
Old 02-01-2023, 10:01 AM   #5
Mooney 78865's Avatar
Thanks again
Haha! Man, I know that feeling!
2014 Georgetown 378 XL
2022 Aprila Tuareg
2005 Jeep Wrangler "Toad"
Mooney 78865 is offline   Reply With Quote
Old 02-01-2023, 07:00 PM   #6
NXR
NXR's Avatar
We had some basement doors that were scraping on the bottom of the frame and the dealer fixed them. I asked how and they were reluctant to tell me but then they did.
They simply take a rubber mallet and tap on the bottom of the door until it no longer drags.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 02-02-2023, 12:20 AM   #7
On your model
The water heater door is not a slam latch door and is held in place by screws. I have the same coach as you.
Jimbo
Your last panel next to water heater panel is pushed in an inch or more to attach to l-frame bracket and gives the illusion the water heater panel is sticking out.
Jc4ut is offline   Reply With Quote
alignment
