09-22-2014, 07:22 PM
Battery/Converter questions
Just purchased a 2003 Forest River Georgetown, my batteries keep running down even plugged in my 50A outlet. Everything else works but I need to keep a trickle charger connected continuously. I don't believe I should have to do this. Where should I look first? Is there a fuse for the inverter and where are the 12V house fuses located on this model?
09-22-2014, 07:54 PM
This subject is totally outside the thread you posted in however since you asked:
Any idea when the Coach batteries were last renewed? Sounds as though they won't charge cause they are old and wore out.
If renewed in the past few years, could be the converter charging section is not working. Are the lights still bright when the batteries are low? If they are its probably the converter is ok or could be both batteries and converter are shot. Start by measuring the converter output while on line book will show maybe 13.6 VDC, be guided by the mfg. Second you can drag the batteries to a retailer and they can bench test called "load testing".
09-22-2014, 08:15 PM
2003 Georgetown converter location
I just replaced the two house batteries one month ago. The batteries run down if I remove the trickle charger. Where is the converter?
09-22-2014, 08:22 PM
Any chance you hooked the batteries up backwards, even for just a second? If so, you may have blew the converters reverse polarity fuses (which means they did their job).
2011 Flagstaff 831 RLBSS
09-22-2014, 08:46 PM
That's why I addressed both. Trickle charging low batteries is not a good idea. The converter of current GT's is in the rear compartment with the shore power cord. Many have "reverse polarity fuses" right on the case exterior. If not there, two large fuses in the panel inside. Run the tests I mentioned before ripping it out.
09-22-2014, 08:47 PM
X2
09-22-2014, 10:31 PM
On my 2005, the converter is in the electrical compartment. Try the battery charging voltage test as previously posted. That will tell you if the converter is charging. Also, there is a converter cooling fan that I can hear with my head in the compartment.
I have been told that the batteries will not charge if the battery disconnect is thrown. Not sure if that is true, just something to check. I know the batteries are new but check the water level.
My converter boiled mine dry last year.
Let us know what you find.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
09-23-2014, 06:48 PM
Tim & Lisa Trempert
This may be obvious, but is your battery disconnect switch turned on? Otherwise the batteries will not charge and eventually run down although it should take several weeks.
Tim & Lisa
2011 Georgetown 350
09-23-2014, 07:32 PM
Memory(which is weak) tells me you may need to turn off 110v breaker for the inverter...wait just a bit and turn back on. Re measure voltage at batteries. On mine, if the batteries happen to be fully charged then the inventor may not start charging.
Cheap check
2017 Puma 297RLSS
