Old 06-10-2022, 05:50 PM   #1
Bedroom slide adjustment
Is there a way to adjust the slide up on a bedroom lippert hydraulic slide-out. It seems that the slide is low on this slide. Any help would be appreciated.
Seabreazer is offline   Reply With Quote
Old 06-10-2022, 08:52 PM   #2
Slide adjustment procedure 370ts
The bed slide adjustment on a 2005 Georgetown xl370ts.
THIS IS FOR THE ABOVE FLOOR MOUNTED FORESTRIVER MODIED LCI HYDRAULIC SLIDE
To adjust the tilt on the bed slide if top seal is not sealing
There are two adjustment bolts under the bed that you can see on both sides of the bed that you can see when you lift the bed.
1)Measure the gap between the slide seals
2) pull the slide partially in.
3) if the seal is gap is not closing fully on top turn the bolt counterclockwise 1/4 turn for each 1/2 inch of gap to move seals closer together.
4)Run slide all the way in then back out to check sealing.
bed, bedroom, bedroom slide, roo, slide
