Old 06-22-2014, 03:55 PM   #1
swiseman's Avatar
Black Tank Flush
New owner her so I may have a goofy question here, but not sure so...there have been a couple of occasions where I was planning to use the black tank flush at the dump site, however there was no water supply that had a hose connection. There was a nozzle to spray out the stinky slinky, but couldn't use the flush. So...is it possible to use water from the fresh water tank, via the outside shower through black tank flush inlet to get the job done? I presume that as long as the pump was working it might get water to the inlet, but sure if I'd have enough water pressure. Thanks for any help you can give.
Scott & Lauren
"On the edge of Normal"
2014 Georgetown 328TS
States Camped: Illinois, Wisconsin, Iowa, Nebraska, South Dakota, Minnesota, Michigan, Indiana, Ohio, Missouri, and Ontario CA.
swiseman is offline   Reply With Quote
Old 06-22-2014, 04:00 PM   #2
Campin Cajun's Avatar
I would think that is very possible. I would just spray the outside shower hose with clorox afterwards.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 06-22-2014, 05:01 PM   #3
fonzie's Avatar
Yes it is possible. You need to make adapter from outside shower hose to black tank connection. As mentioned above, would use clorox afterwards.
Fonzie
Old 06-22-2014, 05:07 PM   #4
themounties's Avatar
Not sure, but at most dump sites there's a hose they have hooked up and the end is like you said, has a sprayer or the end of it cut off, I just unscrew theirs and screw mine on hook it up and flush'er out, and after, hook theirs back up.
themounties is online now   Reply With Quote
Old 06-23-2014, 05:05 PM   #5
Freds342's Avatar
I don't believe the 12-V pump has enough oomph to properly operate the flush. JMO, though.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 06-26-2014, 08:23 AM   #6
Maybe one of these could help: Water Thief Hose Adapter Connector for Unthreaded Faucet RV Home New | eBay
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 06-26-2014, 08:40 AM   #7
bend302's Avatar
In lieu of a hose, you can fill the toilet bowl a couple of times and use the weight of that water to flush the black tank.
A lot easier than jury rigging something.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 06-27-2014, 08:35 AM   #8
swiseman's Avatar
alparmer, thanks for the link. I'll have to think about getting that. All else fails there's always the campground close to home/storage that has a good setup. At least I can put it away clean.
Scott & Lauren
Old 06-27-2014, 09:43 AM   #9
bend302's Avatar
We have a campground just a couple of miles away and use it whenever we have been out and need to dump & flush. We take the opportunity to vacuum, clean and water batteries, etc. before we put in storage.
We still add a few gallon of water and a deodorant pack to the black tank.
Bill
black, black tank, black tank flush, tank
