Old 10-02-2022, 10:08 AM   #1
Blackstone 17” and Quick Connect Connector
We bought a quick connect gas hose and an elbow fitting to attach to our Blackstone 17”. We can only get a low flame on the griddle in this configuration. We’ve tried turning off the gas on the RV to reset the regulator. Same result. Does anyone have a suggestion we can try before we purchase another adapter kit from Blackstone directly? The current kit we have was purchased off of Amazon. Thanks.
sinirgi is offline   Reply With Quote
Old 10-02-2022, 10:27 AM   #2
Homebrew's Avatar
Pictures would be helpful.
I’m assuming your RV quick connect is regulated after the tank and your black stone has a regulator, so you have two regulators feeding your black stone. Just a guess not knowing all the details.
I have a adapter going from my main tank to a hose then connected to the regulator of the black stone.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 10-02-2022, 10:33 AM   #3
Are you saying there are two regulators before the quick connect on the side of the RV? If so, then maybe I need to find the one closest to the one on the side of the RV and reset that one. No regulator on the Blackstone side. The hose goes directly from the RV quick connect to an elbow connector attached directly to the Blackstone.
Old 10-02-2022, 10:47 AM   #4
Homebrew's Avatar
Your RV should have one regulator to control the quick connect , if you delete the black stone regulator than it’s just one.
2014 Ram 3500 DRW
Old 10-02-2022, 10:50 AM   #5
So isn’t that the suggested configuration for Blackstone? One regulator on the main tank, and the rest is all hose plus the elbow?
Old 10-02-2022, 11:14 AM   #6
Homebrew's Avatar
Yes one regulator only, the blackstone requires a .5 PSI regulator, check your Rv regulator to see if it’s lower than .5
2014 Ram 3500 DRW
Old 10-02-2022, 11:31 AM   #7
10-4. I guess there’s no way around it without measuring the gas output at this time. Thank you.
Old 10-02-2022, 11:57 AM   #8
rmac04401's Avatar
Take away the elbow. I use the hose that has the blackstone fitting on the end straight from quick connect. I have good flame. You may also reference your owners manual. I believe there is a way to adjust your flame settings just like on a grill.Click image for larger version
ID:	279940 this is one that I use
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2011 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 10-02-2022, 12:04 PM   #9
Thank you. I’ll try and remove the elbow. I’ll update another day.
Old 10-02-2022, 01:13 PM   #10
NXR
NXR's Avatar
This works great with our 22" Blackstone: https://propanegear.com/blackstone-1...ct-12-ft-hose/
Note that some people have bought Amazon hoses and the end that connects to the motorhome was the incorrect size.
You do have the little lever on the propane connection on the motorhome turned all the way, so the lever is inline with the hose, right?
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 10-02-2022, 01:13 PM   #11
Part-Time Campground Host
cboss's Avatar
Here's another option for the hose with fitting. It's 24 ft and we do like the elbow. Works great on our 22" Blackstone.
https://www.amazon.com/dp/B08KZNKKBV...t_details&th=1
Craig & Cath
Days camped since 2015(retirement): 1317
cboss is offline   Reply With Quote
Old 10-02-2022, 01:29 PM   #12
Yeah. I get flame on the Blackstone. Although, the flame is too low. Valve is open on the RV for the quick connect.
Old 10-02-2022, 01:31 PM   #13
Hmm...
The typical RV pressure out of the regulator is 11-14" w.c. which is about 0.5 psi. If the furnace is operating properly, pressure is likely okay.
Larry
Larry-NC is online now   Reply With Quote
Old 10-03-2022, 08:10 AM   #14
Homebrew's Avatar
I’ve had 4 regulators fail on my Coleman stoves in the past few years and now I’m finding comments on line about Black stone having regulators fail. It looks like they get there regulators from the same company “ China”.
Also try shutting down all your propane appliances in your Rv and turning on the main valve slowly after a few minutes. In many cases this will reset the safety on the tank valve and allow propane to flow a full capacity.
2014 Ram 3500 DRW
Old 10-03-2022, 09:11 AM   #15
Some suggest...
Some suggest making this a four-step process:
  • Close valve(s) on propane tank(s).
  • Open valve on one appliance to remove pressure from the downstream side.
  • Close valve on appliance
  • Open tank valve slowly
Regulators have a very thin metal plate inside, called the diaphragm. It flexes dependent on the difference between gas pressure and external air pressure. As it flexes, it actuates a needle valve which performs the regulation function. It's a fact of life that pinholes form in the diaphragm disabling the regulation function. Sometimes they are so small you can't even smell the tiny bit of propane that leaks through. Because the diaphragm is so thin, a tiny bit of corrosion on one side will rapidly progress through to the other side.
This is not limited to propane regulators. I've had the same failure mode occur on water-pressure regulators in our sticks-bricks home. City water pressure here is 140 psi--when regulator failure begins, the toilet ballcocks don't shut off completely. If I don't replace the regulator promptly, the Over-temp/Over-pressure valve on the water heater trips. That gets my attention promptly.
Larry
Old 10-03-2022, 09:20 AM   #16
Interesting and possibly your kit has something wrong with it.
I too bought an elbow from Amazon (already had the hose for my fire pit) and my 17" Blackstone works perfectly off the low pressure quick connect.
This is the ell I bought...
DOZYANT 1/4 inch RV Quick Connect Adapter Conversion Fitting Elbow for Blackstone Tabletop Grill - 17 Inch and 22 Inch Portable Gas Griddle
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 10-03-2022, 03:27 PM   #17
Dodge Guy's Avatar
I bought that same kit off Amazon and it works perfect. The regulator is in the tube that threads init the Blackstone. So with this kit it removes that regulator. Either you’ve got a bad valve or a low psi regulator on the MH.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-03-2022, 03:36 PM   #18
Have you tried anything else on the low pressure quick connect?
Maybe the supply line is kinked or pinched somewhere and there's nothing at all wrong with your Blackstone or the quick-connect kit you purchased.
black
