Originally Posted by Mikehug
I have a 2011 motor home Georgetown
On one side I have to change a defective camera but don’t want to break something else so can anyone know or did change one before and the coast of the camera
Thank you ahead because I had small problem before and you guys really help me out
Michel
I just ordered both right and left cameras to replace the failed ones. These are from Miko Corp in Elkhart, In. If these are what you have, there is a small hole near the bottom front of the cover. I used a small hex key and slowly lifted up. Then , go underneath the hood and find the cable that comes inside. A few feet in you’ll see a screw on 6 pin connector to the extension cord that runs to the monitor. The cameras alone are $150 each. The kit for 2 cameras, gasket, cover, mounting brackets is $350. If you don’t have the Miko cameras the above info is probably similar to another brand but could be different. I have a 2012 Georgetown 328. I Spoke with one of the engineers who said Georgetown changes vendors often. Also, he said if you get 4 years out of them you’re lucky. Keeping them covered in winter time or bad weather probably helps.
