Old 06-13-2024, 06:54 PM   #1
Camera with no signal
Hello, we have a Georgetown 31L5, year 2020. My left side and my rear camera are not working. I get the No Signal on my screen. I was wondering if there are any fuses for the them? If so where are they, I have already check the one by the brake pedal and also the one in the hood on the fire wall. Or with this code both of the camera have to be replace. I could use some help to solve my problem. Thank you.
Leopard is offline   Reply With Quote
Old 06-13-2024, 08:26 PM   #2
bikendan's Avatar
Moved thread from the Tech and Repair section to the Georgetown sub-forum for better help from other Georgetown owners and possible factory support.
Old 06-14-2024, 09:25 PM   #3
NXR
NXR's Avatar
If you have the Jensen XRV10 radio/camera display the radio itself supplies the power to the cameras. If you have checked the RCA connectors on the back of the radio where the cameras plug in and they are OK you either have bad cameras or a bad radio.
Since one camera is working you should be able out figure out which one that is and plug it into each of the XRV10 connectors. If the remaining camera works in all three positions then you have two bad cameras. If not, the radio probably is bad.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
camera
