Originally Posted by northernlights
We are in the process of a reno and removed the captains chairs to lay new flooring. We were surprised that the bolts were not grade 8. I am seeing some recommendations for grade 5 and some for grade 8. Which should it be?
FWIW, Demco uses Grade 5 hardware to fasten the baseplate on the Equinox and also supplies blue Loctite, not red.
I learned a long time ago that when you increase the strength in one place all you've done is transfer the failure point somewhere else. It "should" all be engineered as a system with shared stresses. (Yes, I do realize we're taking about RVs here...)
How are the seat belts anchored? I'd be at least as concerned with those attach points, especially the shoulder harness to the wall.
Ray
