CHF - A terrifying mod, just don't.
I have an F-53 and read the CHF threads with great joy. I even went out and started to make the mod on my rig. But it quickly became clear that, whilst it might work, it completely changes the dynamics down there. The sway bar is intended to limit sway by using torsion (twisting of the bar). If you make this change you are essentially changing the geometry and eliminating the torsion effect and using the swaybar like a straight-arm. The potential to hit a bump and simply rip something off the frame is very real - in my mind at least.
So instead I spent the ~$600 on a Helwig heavy duty sway bar for the rear. It can be installed at home, but you will need at least a 24" breaker and lots of elbow grease. The result was amazing, I followed up with the front sway bar but it probably only added a 10% improvement over the rear. The old girl rides like a city bus now.
Anyway, I hope this helps. I would definitely get the sway bar. My wife used to be terrified in the passenger seat, now we roar around corners at the posted speed limit in comfort. All those little micro-adjustments you make with the steering wheel are gone, I can drive with 2 fingers like a normal car, much less tiring to drive now.
