I don't have an answer for you but I found this on Crutchfield and it seems like it applies to you. Are you sure you need an adapter? Clarion says the mic works direct.
"RCB-199 and NX501 Headunit Angelo from Tampa, FL on 12/22/2011
Verified customer (What's this?)
I waited to install the mic for 8 mos because I was waiting to buy the HD tuner and install both at the same time. Well the mic has so much static at any setting the other end cant hear you at all. After some research on the internet I found out that Clarion techs have confirmed the mic doesn't work in the NX501 and from what I read its a hardware issue so a software update most likely wont work. Maybe later units will work but I bought this head unit when it first came out in Feb of 2011. So I cant return the mic because of it being so long ago of an order. I also tried using a different mic to test with so now I definetly know its an issue because of the headunit. So if you buy this mic for an NX501 test it immedietly so you can return it if need be.
Pros: nothing
Cons: Doesn't work with the Clarion NX501 [Editor's Note: Thanks for your comments. We asked Clarion about this and received the following message from their technical services manager: "We have tested the RCB199 with the NX501 and it does work. This customer may have connected the RCB199 into the SWI jack (steering wheel interface jack) instead of the microphone jack.
EDIT...I just took a look at your owners manual and an EXTERNAL mic jack was packed WITH your original unit with a square plug and standard mic jack. My guess is that cable might be available from whatever remnants of Clarion support remains in this country. They stopped selling in stores in 2016. Good luck!
________
Cam
2015 Georgetown 280DS
